Re: '89 CRX HF + D15Z1 troubleshooting...
I unplugged the IACV on my 87 Integra with 1.6l because of the surging issue. I just left it in place. I made my own adjustable throttle stop and I did get a stable idle but it would nearly kill the engine when I ran the AC.
I had to plug a $1 radio shack resistor of the same ohm value as the IACV into the harness side of the IACV connector so the ECU would still think it was there- before I did that, I was getting a CEL for it. I was happy with the overall result. That car would get 37 mpg at 65mph- even turning at 3500 rpms... |
Yes
Well I would say cleaning the IACV is a "cheap" method to fix your car and it's actually effective.
I re-inspected the IACV to be sure, it was soo clean even the mesh was shiny. I unplugged it & reset the idle according to HELMS, I didn't have a diagnostic tach so I went with the dash tach (inaccurate I know but all I had) and turned the idle screw 1/3 turn (counterclockwise to raise idle a hair). It's more of an experiment than fixing it, I won't know anything until I drive it around some this weekend. Again, my TB was deep cleaned before I installed it, I don't need to retread there. What's the next easiest way to check for vac. leaks besides the spray-carb-cleaner-everywhere-and-listen-to-the-idle way? Thanks, Mak
Mak- a vac gauge might help you see if you have any moderate leaks. I have read that some repair shops use some sort of a smoke machine to find vac leaks- the fill the intake with smoke and look for puffs around hoses etc. Any chance that your EGR valve is stuck open a little bit? |
I'll try and activate the IACV this weekend. The EGR might be a tad harder to clean considering the bolts are severely rounded off already (even when I used a brake line flare nut wrench) so removing it will be a hassle. I have a Vac gauge already hooked up to both my Hondas and I may try and take some video of it when I'm out and about next time under load, decel, idle, & comment when the issue creeps in. Is there any other way to clean the EGR w/o removing the solenoid itself just in case I'm unable to get the bolts off?
Yeah, most rust removers are acid based.
https://en.wikipedia.org/wiki/Calcium_Lime_Rust
Eh, the EGR's bolts are destroyed...they won't budge & nothing will grip them beyond an infant's strength to turn them. I PB Blastered them overnight but they are too far gone. In other news the IACV clicks fine w/ supplied 12v & back when disconnected. My thought would be to drill/grind the nuts off if I have to but the one closer to the fuel rail is a tight space for sure. I'd have to drill the bolts out completely and use a hex bolt/new nut combo to tighten her back down. Never used CLR for car-related stuff.....
As a last resort, I sometimes use a hammer and long thin chisel on rounded off nuts to spin them loose.
The chisel needs only to be moderately sharp and you need to angle the chisel as much as possible to get it to rotate but not so much that you end up carving off chunks of the nut. If you have a welder and enough clearance, you can sometimes place a large nut over the rounded nut and weld the two together. |
I'll try the chisel method, I don't have a welder handy, it would come in handy on days like today.
***update***
Never got the EGR off and the nuts are now officially mutilated. Once I reset the idle w/ a bias towards high (we're talking 50-75 RPM max) she cleared up most of her gremlins that are idle related, still have noticeable rev in neutral overrun. I have to focus on house related crap now so I may lay off smoothing her out til I get some extended top hats to lessen the Eibach Sportline thunk. Thanks everyone, Mak |
Lots of info- thanks a lot all! :)
BTW "The PCV valve is new, and with the straight-through VX design I don't see how it can fail, it's just a hollow elbow." Maybe important for some - the elbow is not the PCV. The PCV is located under intake manifold (hard to reach but possible when you put your whole arm between firewall and intake manifold). Cheers! |
one of these days I'll get a video of the "fickle Shift light". Below 2k and usually in 3rd gear up a decent hill, the shift light will flicker like an old fluorescent bulb until it builds enough RPM's and decides to stay on solid green. Still has neutral rev overrun, but the original cruise/buck issue is much smaller at the moment.
I should have done this one post #1...better late than...
This is "cruise/buck". https://youtu.be/rLj6wmSDDRc This is "fickle shift light". https://youtu.be/EJCU98uB-ik I believe these problems are related. Any suggestions? Thanks, Mak P.S. Is there a way to embed these videos? |
I've created a new thread just for videos, as this thread is too long for some attention spans...:)
