DarbyWalters |
04-02-2008 10:56 AM |
Well you need to brush up on more current 2 stoke engines. Reed Valve 2 Strokes do not "lose" the fresh fuel charge like the older piston port engines. Also with Direct Injection of Oil from a separate system, the PM (particle matter) and HydroCarbons are greatly reduced (no need to premix oil/gas which caused most of the ppm pollution). This is not a weed-wacker or Go-Kart 2 stroke. I know about the pollution problems in Asia from 2 stroke engines...but that is caused by older (not as refined) 2 Strokes and vehicles that are "over burdoned". They are taking simple "bikes" and making them into three wheel "taxis" carrying much heavier loads than they were designed for.
You also have to compare ppm of pollution to volume of fuel spent. On top of that you need to add the pollution caused by transporting the fuel to your station. If I use 28% of the fuel I was using in my Jeep for my Direct Oil Injection 49.3cc 2 Stroke...the net effect is less pollution overall. My scooter has traveled over 1,000 miles and still has not used even 1/5 of a quart of 2 Stroke oil. I also do not have the added pollution of oil changes and oil filters. The older 2 Strokes would use a full quart or more over the same 1,000 miles. Even the CVT transmission is dry and requires no oil/lubrication that would eventually would become pollution. Premixing, Overloading and Piston Port Engines were the biggest problems with 2 Strokes when it concerns pollution. The simplicity (less moving parts) and power/weight ratio (smaller displacement) of a 2 Stroke allow the use of a much smaller engine than a 4 Stroke to get the same performance.
I know this might go against everything that most of us have learned in the past, but they have made improvements and packaged the products more efficiently. Kind of the same stigma with Diesels of 5 or more years ago.
