GasSavers_Otto |
03-31-2008 06:44 PM |
Originally Posted by BluEyes
(Post 95003)
The water pump is engine driven and is turning all of the time no matter what. If anything, a hotter engine would result in less water pump drag because the thermostat would be open, resulting in less resistance to flow and less power being drawn by the pump.
Cooler underhood temps will help anything rubber or plastic live longer though.
Well, maybe not--even though the water pump is turning all the time, the load imposed on it by pumping through the radiator is probably greater than if only just the coolant in the engine. In other words, with the T-stat open the pump has a significantly greater mass of coolant to move, over a greater distance and in a draggier pathway.
I agree that cooler underhood temps are better for most things that reside there, especially rubber or plastic.
