FS: VX Rear Brake Parts,CIVIC OEM clock, 14 in Honda wheels/tires, ALL CHEAP, PICS!
I have the complete rear brake setup off my '95 VX for sale. Nothing really wrong with the brakes, but the one bolt on the trailing arm is stuck, but I can cut it off for you.
Bushings in the trailing arms are no good. Shoes are not great but will still pass inspection. Brake hardware is literally 2 weeks young! E-brake cables work perfect. Wheel bearings/hubs/lug nut studs are perfect. Wheel cylinders are recently replaced and perfect Brake lines are good, no cracks/leaks. I just swapped in a low mile disc rear brake setup and the disc brake prop valve, so that's why I'm getting rid of the stuff. Best offer on anything takes this stuff! I will ship anything at the buyers expense. Brake pix (I have both sides, took pictures to represent what's for sale): https://www.fuelly.com/attachments/fo...f564289fb6.jpg https://www.fuelly.com/attachments/fo...e498d5a707.jpg https://www.fuelly.com/attachments/fo...b6f9f4ffa4.jpg I also have an OEM 92-95 Civic clock for sale that is tested and works perfect as well as being in great shape visually! It will plug into any civic even if it doesn't have one from the factory (they are still wired for them!) PICS (one is of this actual clock working and being tested!) https://www.fuelly.com/attachments/fo...8f5e3cdb50.jpg https://www.fuelly.com/attachments/fo...8409fe5116.jpg https://www.fuelly.com/attachments/fo...76e816d5f0.jpg https://www.fuelly.com/attachments/fo...48b7cd6e37.jpg $25 Shipped! PLEASE EMAIL me at dantheflemwod@gmail.com if you're interested in anything! I'm open to offers on anything listed here since I'm moving in two weeks and need this stuff gone before then!!! |
