Start Odometer Reading
How do I set start odometer reading? I need this otherwise the first tank is not calculated into my statistics. It will not let me put a 0L fill in to attempt to fix this.
I'm not sure exactly what mean. You can switch between odometer tracking and tracking miles per fuel-up on your vehicle settings page. Here's a bit more info. We use all of the information we can in calculating your average fuel economy, even if an individual fuel-up doesn't have a calculated MPG.
You don't enter a "START" odometer reading. Just wait till your second fill up. I had to. :P
I noticed that right away. I created a dummy car and played with it to see how things worked. I'm used to entering a start odometer reading and ignoring the cost of the initial fill as the basis of tracking is full tank to full tank. Now the cost of the first tank is included.
All is good it will work out in the end I just had a good first fill mileage... pity. I just created a dummy fill before it for the dealer km's and first fill. |
