New to HHO need some ideas!
I am trying to add an HHO generator to a truck. I have several questions I hope some one on here can answer.
1) What mixture should I put in the generator? & How much of each? (distilled water, baking soda, vinegar ext.) 2) What is the best design and products to make the generator out of? Anyone have any pictures and or information to share would be great. Any advice at all will be appreciated. |
https://waterpoweredcar.com/hydrobooster2.html https://www.fuelsaver-mpg.com/documents.html https://www.alternative-energy-resour...uel-store.html https://peswiki.com/index.php/OS:Water_Fuel_Cell good luck. |
I'd start here:
https://smacksboosters.110mb.com/ Run it derated at maybe 10 amps to start and go from there? Need to keep it cool...best place is in front of the radiator if possible? |
simple
https://www.free-energy-info.co.uk/Hotsabi.pdf
and cheap:rolleyes: |
That is some pretty easy construction...I think it's been criticized a lot due to the simple bolt used for the + side? But that doesn't mean much if there are good mpg results. I think the bolt works because of the threads...lots of small radiuses? Needs to be ss for sure.
I think the water4gas cells use the same principle...with the wire electrodes. That's one of the MAIN PROBLEMS on the hydrogen forums...too many pushing the perfect electrolyzer...instead of just building one and getting some experience? Newbe gets on a forum....lots of confusing info. If you read all the info provided by the various LINKS...your head will be spinning for months....I know. I think some people don't see results maybe due to the vehicle they install on or the way it's set up...then they go for the most efficient design...or designs that put out mucho gas. The Tero cell is nice...but is technically more difficult. What's a newbe to do? Got to be able to make or buy one. Need to have room for it. Needs to stay cool. Don't know whether it will work or if you are wasting time and money. |
