Turned to the Dark Side
10 Attachment(s)
Here's my introduction. I got tired of my 100miles of commute and my usual ride with its 18mpg. I've got a couple of gixxers, but you can't drive those all the time. Picked up a $300 crx, took the fart can off it and started a little project.
https://www.gassavers.org/attachment....1&d=1211159661 https://www.gassavers.org/attachment....1&d=1211159661 grill block, air dam, side mirror removed https://www.gassavers.org/attachment....1&d=1211159661 currently working on the skirts |
neat! you can at least double your mpg with the crx, unmodded.
6 Attachment(s)
skirts are finished and on. made a hood vent to help deal with the grill block, block off plate for the side mirror, and removed the rear wiper. got some clean up work and some other projects before we paint this thing.
https://www.gassavers.org/attachment....1&d=1211246922 https://www.gassavers.org/attachment....1&d=1211246922 https://www.gassavers.org/attachment....1&d=1211246922 |
Why cut a hood vent when you could just unblock part of the grill?
no issues with overheating, but it's only been in the 60's here. Also I've gone from 35ish mpg (this is an si and it's short gears) to 45 mpg. I've got to air up the back tires and build a belly pan, hoping to reach 50mpg.
Yeah I think you're better off pulling air from underneath and venting it out the top than letting it all go through the front... newer cars are made more like that.
However, I could see you having issues in hot weather with that warm air pulling into the cowl vents and cooking you. |
You could also pick up an HF trans for under $200, that would seriously up your MPG as well. |
Looks awesome!
Really reminds me of the Honda Insight in the profile shots with the rear wheel skirts. |
