2006 Or Thereabout Matrix Owners?
My Matrix is a 2006 Xr, 5 speed manual. Fun ride and everything, however, I'm finding that I'm only getting "sticker" mpg on it with a combo of city/interstate driving (I drive, ugh, 78 miles a day in the work commute, hoping to change that in the next month though to something in the 6 mile range). Anywho, my maximum mileage thus far is 36.8 mpg, with a running weekly average of 34 to 35 mpg. I'm using some hypermiling techniques that I kind of noodled out on my own (coasting, taking it out of gear, P&G in city, engine off at lengthy stoplights, etc).
My daily drive is 20% city and 80% interstate, each way, approximately. I understand that reliably getting 35-ish mpg with this combo is pretty good all things considered, but... The car has no modifications whatsoever. None. The mileage I'm getting is coming strictly from habit changes. Ok, great. Most Matrix owners I know in my area get like 24 to 28 mpg with their "normal driver" driving habits, so I'm ahead of the pack. However, looking on a Matrix owners forum I see routine claims of 40mpg to 46mpg from people who rarely if ever indicate any kind of modifications or driving habit changes and are driving similar age Matrix automobiles. Am I missing something here? If I'm not missing something and they have some kind of secret for better mileage, would anybody have any clue what that might be? Air dam comes to mind, the bottom of the 2006 Matrix looks like it is grinning from ear to ear. Other than extreme modifications that my wife would totally balk on, is there anything really "big" that I'm missing (and are there ways to hide "extreme" modifications from a spouse that kind of only tolerates one's eccentricities)? My tire pressure is set to 44psi, btw, which is the max listed on the tires. Thinking of popping it up to 50psi, assuming this is still a safe range psi for an auto that potentially carries my kids from time to time. Any suggestions or observations? |
what speeds are you running on the highway? speed is one thing that will kill you.
if the speed limit is 55, do 55. if it is 65, then do 63. (I try to stay away from 65 or higher) just a thought. also isn't the matrix the same as the pontiac vibe? |
Highway speeds are 65. I run at 65. Will try 63 this evening and for the rest of the tank. Will a 2mph reduction make a noticeable impact I wonder? I've considered doing 55 mph and running behind semi trucks, since their max is pegged at 55mph in Ohio, however, most of them go as fast as they can in between smokey the bear sightings, so it's kind of hit and miss for sitting behind them at 55. I think the Vibe and the Matrix are more or less the same. The Matrix has been around for quite a few years (2003 or prior I think, not certain) and is essentially a Corolla with a different body, probably on the same frame (guessing on the frame of course). Same year Corollas get 40mpg-ish I hear, so some aerodynamic tweaking might be required on my part (or blocking that damn dam, lol). On 44 psi rated tires, a 50psi fill shouldn't be much of a strain I would think? |
personally, I get my best mileage at 50mph but on a highway that the speed limit is 65, that is all but impossible. the slower the better because aero will kill your mileage. I just suggested 63 because it is less than the speed limit. if you can stand to do 60 then I would try that. as far as drafting trucks, I wouldn't do it. the last thing you want is a ticked off trucker.
as far as aero goes, you might want to look into a grill block. there is a guy here with a vibe and a lady here with a matrix (same thing, different color) they have huge grills. I would block that off first. this helps with engine warm up times and aero as well. you can use plexi-glass (well fake plexi) and it doesn't look that bad. check my garage if you want to see mine to get an idea. as far as the tire pressure thing goes. just one simple coment "blowouts suck" |
You can use your CB to ask permission to draft. There is at least one person on the forum who does that. However, a 2 or 3 second following distance is further than most people use on the highway anyway. Try it, you'll be surprised just how far 3 seconds is at 65mph.
Blowouts happen from excessively high temperature, which results from underinflation. Overinflation will not cause a blowout unless it's really extreme -- I'm guessing you'd need 150psi in a 44psi tire to cause anything resembling a blowout, at which point you'd actually have the bead come unseated and the air come out around the rim. Maybe 100psi could do it if you hit a sharp pothole hard. |
Also considering my next oil. I think a 0W-30 synthetic would work. Are there recommendations anywhere on what kind of spark plugs/wires to put in a little putter like this one to be found? Sorry for doing so many noob questions, this kind of thing fascinates me. You should see how energy efficient our home has become the last 5 years from my inability to not be fascinated with stuff like this, lol. |
I do a 2 second+ lead on my motorcycle for ALL vehicles in front of me, because I have this peculiar aversion to death or serious dismemberment. Yeah, it's kind of stunning how big a gap that leaves. Quote:
Take a look at mods others are doing. Most have to be free or nearly free to pay for themselves. Grill blocking and warm air intake are two popular mods. |
