Versa Mods?
Any ideas on light modifications for FE for a Nissan Versa? I'm new on this website and I've been thinking on getting a Scangauge 2. I've heard of grill blocking but I live in California and it seems like that would make the engine overheat?:confused:
Any replies are greatly respected :) |
what I did with my grill block was to make it in sections so that if I did have an issue, I could take a section off of it. especially if it happened and I was a good distance from home. I used wingnuts that were easlily removable. I also used a scangauge to keep up with my water temps.
I also use the scangauge to watch my intake air temp for my WAI. I did good with my WAI and got about 10%. I am waiting for a few tanks to say that I definitely got that amount though. simple concept, doesn't work for everyone. take a look in my garage to see the pics of what I have done if you are interested. when I started on here about 2 months ago, I was getting 30MPG and now I am getting about 35 or so. my two baseline tanks killed my average. working to get it up now. also, pump up your tire pressure. simple trick with descent returns. usually get an mpg or so. definitely worth the money (75 cent at the quick-E mart) |
Thanks for the advice BEEF haha, I'm gonna pump my tires up like you said, but can that cause excessive wear on them? And down the road I might try to make a grill block out of plexi glass like yours or some choroplast.
What is the maximum pressure stamped on the sidewall of your tires? What are the size markings? A little googling tells me that your car weighs 2,600 to 2,800 pounds.
Increased pressure has always reduced wear for me, but YMMV. Anyway...Congratulations! You are the first recipient of my new canned post about tire pressure... Tire Air Pressure Myths and Facts A canned post by theholycow Increased tire pressure is a cure-all for problems, and generally an improvement even when there are not problems. I have been driving with greatly increased tire pressure for hundreds of thousands of miles, and have not suffered ANY consequences, though other drivers with other vehicles could. I have only benefitted from it. There are limits, though. You should never significantly exceed the tire's maximum pressure rating, which is stamped on the side of the tire (often next to its maximum load rating, which requires the maximum pressure). If you add pressure and find that your handling has suffered or your ride is terribly harsh, you should reduce pressure until that issue is gone. Those things are very important limits. If you exceed them, you could possibly cause a tire failure (though I doubt it); however, real consequences may include center wear, possible liability in an accident, and sketchy handling that could cause an accident. Within those limits, you can find the following advantages: - Decreased rolling resistance which means increased gas mileage - Better handling due to reduced sideways curling of the tire under the lateral load of a hard curve - Better handling due to quicker response from less tire flex - Better wear, unless you normally wear tires perfectly evenly and always get more than their treadwear warranty out of them If that's all so great, why do car manufacturers not recommend the full pressure of the tire? It's because they recommend the lowest pressure that their legal department approves based on industry-standard load-inflation charts. For any amount of load on a tire, there's a minimum safe inflation which provides the softest ride. To sell cars, they want the ride as soft and compliant as possible when you test-drive it. More pressure isn't bad, it's just not traditional to try to sell a car that way. Modern automotive tubeless radial tires are NOT subject to the same types of failure as the bicycle tires you remember popping as a child. They won't blow off the rim (unless you use way, way more than their maximum rated pressure). They won't pop when you hit a bump. They won't explode in your face. They almost always fail from underinflation (which causes overheating) or a break in the sidewall caused by an impact (which is less likely to happen if you have more pressure preventing the bump from squeezing the sidewall against the rim). https://www.tirerack.com/tires/tirete...e.jsp?techid=1 has a section cautioning against overinflation which includes this: Quote:
https://www.officer.com/article/artic...on=19&id=27281 Here's selected pieces: Quote:
I had a 1997 Pontiac Grand Am SE V6 with P205/55R16 tires. I bought some Bridgestone "Turanza T" tires, which lasted about 70,000 miles (that was less than 3 years for me) before the sidewalls were cracked and the tread was worn at the corners. I ran them at the pressure printed on the car's door post, which may have been 30 or 35 psi. I replaced them with the same, but inflated the new ones to the tire's maximum pressure, 44psi. Handling went from soft and sloppy to responsive and decent. Ride did not suffer. They wore perfectly evenly and had 80,000 miles on them when I sold the car -- and they were still good for more miles. On my 2002 GMC Sierra 1500, I keep my tires inflated to their full 80 psi rating. Sometimes I run the rear tires a little lower, because the handling gets sketchy with the bed empty and the road surface slick. Other than that, I get long, even wear and decent handling. |
Thanks Holycow, that was very informative, next step is to see how much psi I can put in them, and after that it's down to the Shell station!
