my wifes 97 mercury tracer ls. what can i do for it?
she's got an automatic mercury tracer ls, basicly a ford escort.
what should i do to squeaze more mpg out of it? i think it gets about 26mpg typically when i ve checked it. |
ok, with the tire pressure thing, which im going to change before i go to work in a few hours, what is the deal with the change in the ride? the braking and safety first. is it going to slide during hard braking or something?
a stiffer ride isnt much of a problem for me. but id like to know what safety issues to be aware of mainly. Should i push it up strait to 50psi instead of starting at 40psi? we both ride around near 30psi currently. |
Take a look at the tire pressure link in my sig. You can safely experiment with higher pressures and decide for yourself what affects ride and handling badly, and just stay below that point. You will get lots of benefits from increasing the pressure.
In general, just keep reading the forum and learning what others are doing. There's certainly a lot of Escort success stories. |
You could change to a lightweight oil. If you pump up the tires, you should either do it a little at the time or let her know, so the difference in handling doesn't surprise her while braking and turning.
Telling her how to drive may help, but I wouldn't have the guts. You married guys are probably braver than I. |
she is actually a more conservative driver than i, or at least a slower one. a lot of times when she drives she forgets where we are going and starts going way out of the way. wont mention why, lol.
It's far better that way than telling her how to drive. Now if she'd only quit driving that godawful Isuzu Trooper...doesn't matter anyway, she doesn't drive much anymore. |
you can get 30 mpg easily with some techniques. my friend used to have a 94 tracer wagon auto, and i can squeeze at least 30 mpg out of it
My girlfriends 1998 escort averages 42 mpg hwy and its an automatic. We use 5w20 oil with one quart of rislone (It stopped the valve train ticking) We also have a k&n air filter on it and I took a Dremel tool and cut a 4"X5" hole in the air box. It seems to have improved fuel economy. I don't know why it gets such good mpg. It has 180,000 miles on it too.
