New Catalytic converter?
:confused: Ok since now I know that I need a new cat, my CEL came back on. Now I did all the major service as posted in my earlier thread. My mechanic took the car back to the smog test station, and he recommended I get a new cat. Going rates out here in LA are $400-500 installed. This by the way is an aftermarket cat. Honda lists the VX cat for $714 retail. My friend who works for honda said that OEM cats should last for about 10 years, whereas aftermarket cats last 4 years maybe? I'm just getting frustrated to the point where I want to get the work done already so I can pass smog. Does anyone here in Los Angeles, specifically in the San Fernando valley have any recommendations as to where to get the work done? I know on ebay they sell aftermarket cats for about $225 plus shipping. I can save myself $ that way and bolt it on myself. Any help would be appreciated.
lol universal cats are generally made at the same place oem cats are...
heck i picked a universal up for $70 a few years ago... do it yourself its not hard... |
cats last as long as the engine runs moderately well. by definition a catalyst isn't used up in the process. ways to ruin a cat: run excessively rich or burn oil to clog it with carbon. run excessively lean and melt it. mechanical damage, usually hitting it on a speed bump or the like.
yup, sometimes they just go bad after time (but like 20+ years)
or they could have had a defect from the factory that let the inside bounce around... |
They're required by federal law to last 8 years provided the engine is running properly.
Besides the things already mentioned, burning coolant ie a blown headgasket, will also destroy a cat. Mechanics LOVE to tell you that you need a new catalytic converter but you rarely do. VX cat is under the hood right on the exhaust manifold. It's an unusual shape because it's also a collector for all four ports. But it's not that hard to change. I recommend that you unbolt the whole exhaust manifold and B pipe and then pull the cat off with it clamped in a table vice. Use a breaker bar and soak the bolts in penetrating fluid. Or if you got an impact just go to town. I love my air tools. Get a new one from summitracing. Magnaflow/Carsound is a good brand. |
mmm impact gun (homer simpsin droolign sound)
i just angle grind the bolts off, you arent gonan get em off... |
