D15Z1 (Civic VX) - clutch sensor ?
Hello.
What is the function of the litle sensor on the clutch pedal ? https://img356.imageshack.us/img356/3104/clutchil3.jpg |
Shot in the dark guess: Clutch-start lockout so you can't crank the starter without pushing the clutch pedal.
My Civic is a european model. I have this sensor but I can start the engine without pushing the clutch pedal :confused:
So, no other function? |
I think there might be either one or two switches on the clutch pedal, depending on the model. One is called the clutch interlock switch. Like holy said, it's designed to prevent you from engaging the starter unless the pedal is down.
There could be another switch on the pedal, which has to do with the cruise control system. Of course a US VX doesn't have cruise, but maybe your VEI does. And maybe Honda decided to put the cruise-related switch on there even if your model doesn't have cruise. I'm surprised you can start your car with the clutch up. I wonder what your owner's manual says about that. I think in the US manual it indicates that the pedal must be down. |
monroe74, no cruise control system on european Civic.
The Civic VEi (D15Z1 engine) is the only one to have this sensor on the clutch pedal. And nothing in the owner's manuel. |
On some P07 pinouts that I've seen, the ECU actually has a clutch input. There are several functions for having a clutch input to the ECU. The example that comes to mind right now is a fuel and/or ignition cut when you put the clutch in.
Mine didn't have it but I wired it in to my AEM EMS so I could have WOT shifting and a 2 step rev limiter. |
It's so the ecu knows when the clutch is being pressed so that it can start injecting fuel again when you press the clutch in if you are coasting in gear and the fuel has been cut.
