Non-aggressive driving
Until recently I had a bad habit of aggressive driving.
Since I have been trying to get better fuel economy though I have changed my ways. I have been experimenting with non-aggressive driving. Shifting up to 5th gear as soon as possible. Keeping my speed as steady as possible and only in the 40-55 range. In the 1992 Nissan Micra I have been testing my economy went from 34.4 mpg (urban) to 37.6 mpg (urban) just from this technique. Is anyone else getting similar results? David www.runyourcarcheaper.com |
A lot of people get similar results. Saving gas and increasing MPG is all about smart driving. After being a member of this forum for just a few days I've read so many different ways to help increase MPG and non aggressive driving is almost always the starting point. Along with that you may want to inflate your tires to a higher PSI b/c that has been showen to up fuel efficiency as well. Just keep searching the form and you'll learn all types of different tips.
By your description, you should have gotten far more than the 10% gain that you got. I would expect at least double the gain you described, and if you were actually driving aggressively (vs. normally) before you should have seen absolutely huge gains.
Perhaps the miracle water-for-fuel stuff you're selling on your website is holding you back. You might want to perfect that for your own use before trying to make click money on it. |
Now I get 577 miles with one fuel tank instead of 434 miles, by driving smoothly.
Keep non-aggressive driving. |
Maybe your car is like mine, aggressive driving doesn't lower mileage by much because your basically driving like that to stay normal with traffic anyways? |
