Add Engine to Ford Edge?
Can you add an engine option to the Ford Edge? They can come with a 2.0L I-4 Ecoboost engine.
They don't usually add engine options (apart from cylinder layout & count for some bizarre reason).
See https://www.fuelly.com/faq/38/Why-don...ehicle-details Not entirely sure that I agree with that policy but they're trying to keep things as simple as possible (which is always a good idea). |
Oh I see what you mean, there is 'Gas' and 'V6' defined, but no 'Gas I4'.
You can do this yourself when setting up the vehicle. Select 'Other', and an extra combo-box will appear. Select Gas, then select 'L4' in the new combo-box. |
Yep, if you choose 'Other' from the menus when you're creating a vehicle you can select alternates that aren't available in the default choices.
Thanks for the help MMUK. |
