GasSavers_bobski |
07-05-2008 06:53 PM |
Originally Posted by civic_matic_00
(Post 109619)
The coil is not "in the distributor" it is in the distributor cap, under the rotor.
Everything inside the distributor cap is sealed away from the elements by a large O-ring and *drumroll* the distributor body. Therefore, when assembled, the space inside the distributor body and inside the distributor cap become one.
Oh, and the ignition coil is above and to one side of the rotor, not under it. Other than the rotor and spark plug wires, it's the only thing that has an electrical connection to the distributor cap.
The ignitor unit is below the rotor - it's attached to the distributor housing and has 4 wires.
Originally Posted by Danronian
(Post 109638)
The main relay should not affect the car after it is running, only when it's being started.
Generally speaking, that's true. But that doesn't mean a main relay can't fail while the engine is running. The typical fractured solder joint symptoms have something to do with heat and the mechanical forces exerted on the relay contacts, so they generally manifest themselves once the relay is warmed up, and the mechanical load has been removed (relay switched off). There are many other ways the relay could fail, some of which would occur while the engine is running, and would permanently disable the relay. Just because the faulty solder joint problem is the most common failure mode, doesn't mean it's the only one.
Originally Posted by VetteOwner
(Post 109649)
if a timing belt snapped while going 80 (high rpms) im betting it would sound like a garbage disposal while he was cranking it from the smashed valves and broken pistons
Not necessarily... You're playing camshaft roulette. The cam has quite a bit of drag to it and not a whole lot of inertia, so when the belt breaks it stops spinning pretty quickly. It's really a matter of how those few out-of-sync rotations and the cam's resting position relate to the movement of the pistons. If a pair of valves happen to be fully open when the corresponding piston hits TDC, you'll be buying new parts. If not, you got lucky.
My money is on the ignition system - probably the ignitor unit. Not that I have enough info to make a sound judgement. :)
