86 CRX 5 Wire O2 sensor Needed
I'm looking for a new and/or properly functioning Federal five-wire O2 Sensor for my 1986 CRX HF. The Honda part number is: 36531-PE1-A02. If anybody could steer me in the right direction I would really appreciate the response. Thank You. :)
https://www.hondaautomotiveparts.com/...NIFOLD+%281%29
$140 for one from the dealership, so I highly suspect that it is not a 5 wire sensor or it would cost alot more, I would check out any of the auto part store in your town and get an NGK sensor if you can as that is OEM on Honda's... well they are not called NGK but I forget what 3 letter name they do use but it will be clear when you see it. |
'86 HF O2 Sensor Needed
