Vx Ecu
I just bought my 2nd vx. It is a 1992. I was trying to figure out if it was a ca or fed model. It has a 5 wire o2 but when i looked at the ecu it was a p07-l00 which i understood was the ca ecu.
I went and looked at my 95 vx and it has a P07-A01 ecu (and 5 wire o2) So question I thought that the fed vx's had the 5 wire o2 and the ca had the 4 wire and thus what's going on with my 92 (5 wire & ca ecu)? Any help would be appreciated. |
Does your dash cluster have an SIL (shift indicator light)? This would be a clue that you're Federal. But of course the cluster could have been swapped. You can also check the sticker under the hood. On a CA car, it will say something like this: "this vehicle conforms with US EPA and state of California regulations." But this is also not definitive, since hoods can be swapped. The other two signs of a CA car are the ECU and the O2 sensor. Also the engine wiring harness, which will correspond to the O2 sensor. |
You have a California car if your ECU ends in l00. I have the same car. You can enable lean burn by simply swapping in a Federal ecu. This only works on 1992 cars. If you had a 93-95 Cal. car, you would have to convert the 4-wire to a 5-wire.
