The size of the engine will become insignificant in the future, because the engine will not be directly connected to the powertrain.
Capacitive storage of the engines energy production will allow you to store 1000 horsepower-seconds of energy, to be applied to the wheels as needed. Make a mental graph of the real time power demands of your vehicle, then understand you must have a sustained power capability to climb steep grades. Its not the oversized engines that are the real problem. It's running them all the time, and running them inefficiently almost all the time. The engines most important quality is its BFSC regardless of its size or power. The failure in current designs is the belief that you need to use the engine to drive the car, which costs you 50% of it's potential efficiency. regards gary |
actually it seems several people are. Adding weight will ALWAYS hurt fuel economy some, but if you are improving other variables more then the weight increase contributes to fuel economy, then yes, you will have a net increase in gas mileage.
If you could add weight to increase fuel mileage, everyone would be placing concrete blocks in their car year round. Also I believe basjoos car did gain much if any weight, he chopped off some significant metal, removed glass, and replaced it with aluminum, lexan and I think abs plastic, which is probably considerbly lighter. |
LOL, in the winter I used to keep about 200 pounds of lead plates in the bed of my 74 chevy for snow traction. Otherwise it didn't go anywhere in the snow.
-jay |
(said theholycow as he ran off into the sunset, laughing maniacally) |
Ok, Jack, Janet, and whatever we're calling the hot blonde this season - we better get this figured out before Mr. Roper gets here... ;)
For what it's worth, my drives with the wife and child on board are consistently about 5 mpg lower than when I'm solo. Low 60's solo, high 50's with them.
holy cow,
never and always are dangerous words. and yes, my statement sounds like something off of a bad cat and the hat spoof. it's never always the same but who's to blame could it be the cat but he is stuck in the hat why not wait and see then you'll find out it was actually me. |
I don't know is at fault |
-Jay |
