As far as your O2 sensor, I'm not sure of your set up, but try removing it after you've been running your car a bit so the threads are nice and hot. I'm not sure if autozone has an O2 socket that you can rent. It would help if they do. Be sure to put some thread lube when installing. |
well, I started simple. I never changed my fuel filter and i'm at 85k miles! it was easy and cheap. Spilled a bit of gas on myself though. anyway, i had to pound the plastic clamp off the filter itself and i thought the filter was empty. so i emptied it into an empty water bottle and the gas inside was black!!! so far so good with the truck running. I need to reinstall some of the stuff I angerly uninstalled:D
