New To H2 For Cars
I Have Some Questions About H2 Generator In My Car. I Want To Know Which Is Better, #1 Using Flat Plates Or Round Rods For The Anoide And Stuff. #2 Is It Better To Seperate The H2 From The Ox Or Just Have Them Both Be Used Together. #3 Where Is The Best Place To Introduce The H2 Into The Engine (toyota 22r Engine).
Thanks For All The Help, I'm Totally New To All Of This. |
1. What's most important is electrode area, 2 bolts in a jar isn't going to do much.
2. Well the H2 needs O to burn, and there's really only one route to get them both into the engine, so separating them only to put them back together again fractions of a second later is a waste of time. 3. This takes some study of your particular engine's vacuum and emission control system. Typical points might be the PCV vacuum line or the charcoal cannister line, with suitable check valves to stop backflow. If you can find a port on the throttle body that makes venturi vacuum at partial to full throttle, that would be a great spot, since then you can introduce HHO while accelerating, whereas the normal vacuum won't pull any in at larger throttle openings. |
