Those Bosch plugs are junk and will give you nothing but problems with a Toyota. Toyota's are known to be picky about spark plugs. I suggest getting the regular old NGK plugs or factory Denso.
Check ignition timing and reset the ECU. Make sure your throttle cable isn't binding. |
Granted, you may not see any more performance than you would from a set of normal Platinum plugs. Calling the plugs junk is a little far. The thought process behind these +2 plugs and theory is sound. Just don't think it works as well in the real world as it looks to on paper. |
