Just bought Civic vx with bad bog problem!
I just bought a 92 vx with 149000 miles on the odometer. I bought it with a bad tranny and clutch, so my friend (who is a honda guy) and I put in a working transmission, new clutch, new rear main seal, one new axle, and a lightened 7 lb flywheel.
My friend talked me into putting on the light flywheel, but after some research it seems pointless. After the swap, I got 44, then 38, 33, 29 and then 26. Something is going terribly wrong and its driving me nuts. My check engine light came on after a day of driving and turned off before I could check the code. It hasnt come back on since. The biggest problem is the car is bogging out every time I give it throttle from 1800 rpm to 3300, roughly. It was doing this even with the bad transmission in it before. My friend thinks it could be a dirty or clogged egr valve. Maybe an O2 sensor? We are going to try to clean out the egr valve tomorrow, so I will repost and let you know if it changed FE! Any help is appreciated! Jeff |
In any case a major tune up is in order particularly if there are no service records. timing belt and related wear items including water pump, an egr kit, all vacuum hoses, filters, fluids... cap, rotor, plugs, wires, the whole mid life go over. That is what I would do, and there is a very good chance that the steps involved in a major tune-up would fix the bog issue. I woulds swap out o2s for new ones as well, there is a thread with purchasing info on what seems to be the appropriate 5 wire o2 for 60 bucks at the top of one of the forums right now. if the car was treated well another 100k should be possible without opening up the motor. https://www.gassavers.org/showthread.php?t=8372 |
Today I tired cleaning out the EGR valve by taking the valve off and tryng to spray inside the whole system with some cleaner, but its very hard to get into the ports. To get into the entire system involves drilling to pull out some port plugs. Theres a thread on how to do it on an accord, which is very similar to the civic:
https://home.comcast.net/~em-engineering/T2T013.pdf After I tried cleaning the car still bogged or lugged whenever you give gas. I have also replaced the spark plugs, and Air filter and am planning to completely clean out the egr system. |
could be a bad egr valve or bad vacum hoses
if the CEL comes back on, see if you notice if the car drives differently--if it bogs less--could be the o2 sensor if it stops bogging when CEL is on.
some cel lights have memory, the code could still be their. also it could be your maf sensor if it has one, Ive seen plenty of Nissan's bog out from running max lean or rich right off of idle all the way up the rpm scale. but that code should point you in the right direction
The VX doesn't have a MAF sensor but it could be a TPS sensor issue or possibly one related to the o2 sensor. Before suspecting anything else I would check the basics like the timing/spark plugs/tune-up items, and if the timing belt hasn't been replaced, it could have slipped, so I would replace that asap if you don't know when it was done last.
From my obd1 honda experience I think the code will still be stored until you clear the ecu manually. Try jumping the service connector to see if there is a code stored. Good luck. |
How do I pull the stored codes?
Too bad your car isn't OBD 2 then you can check the value of your O2 sensors like I can with my 99 HX and an Auterra Dynoscan.
