Also keep in mind hypermiling is more than just coasting with the engine off. After using the advanced techniques for awhile, a person likely couldn't go cold turkey to none. They would probably use the basic ones out of have habit.
For those that are worried about engine off problems, driving with load can be effective. |
Yes there is more than just coasting with the motor off. Planning ahead is the greatest thing. It takes a lot of practice, but once you get good at it it becomes automatic to me. Also the engine off causes in my case for the power steering needing a lot of force. That is why I am thinking about getting a newer car with electric power steering
I agree with the OP that squeezing 2-3mpg more FE (5% less fuel) when you are already at 52mpg may not be worth it IF you damage your starter.
It seems to me however, that driving efficiently (ie conservatively) has several benefits: - Obviously, less fuel cost for same trip distance** - Driving posted speed --> no speeding tickets, less chance of accident and lower insurance rates. - Less wear on the vehicle drivetrain, brakes, suspension etc. --> less maintenance and depreciation costs - Fewer stops at gas stations --> less chance to buy junk food too - Minimizing stops/braking --> avoid drive thru restaurants --> avoid food $ and generally poor calories ** If you are really concerned with lower total cost of using the vehicle, just drive less and consider taking the routes that consume the least fuel and distance. These may not be the ones that give the "best" mpg or l/100km numbers. |
That's a good point that people overlook, its not just about fuel costs. The more strain you put on wear and tear items like oil, brakes/pads, suspension and tyres, the quicker they will wear out.
