The Mini EV, get involved now!
https://www.mobilemag.com/content/images/15803_large.jpg
I would consider this a call to arms folks. If you want a Mini EV, please read the following email I received and get involved! Here are some news articles about it: Mini Cooper Going Electric For USA In 2009 Electric Minis Headed For California Email I just received from MINI: Quote:
the 100 mile range is pretty awesom.
the 50k is pretty steep though. did they say anything about charge times or how much a charge will cost with a given electric rate? |
Trouble with the Mini as an EV is that space utilisation in it is obscenely awful already, so where are batteries gonna squeeze in? Seriously, if Alex Issigonis the original minis designer had that much room to work with, same overall dimensions, it would have been a 7 seater minivan with fold down beds and an optional removable kitchenette that fit in the trunk space.
BTW, Issigonis did do a "bigger Mini" with similar exterior dimensions, it was restyled however before release by Pininfarina and the styling dated quick. Ergo not so much an evergreen classic as the mini was. It was the Austin/Morris 1100/1300 and was generally acknowledged to have the same interior space as a standard european sized "family car". My Grandad had one, it could get 3 people across the bench on the back and 3 in the front bench. It was 600lb lighter than that BMW thingi. The "BIG" mini type the 1800 was only about 8 inches longer also, and still narrower and lighter. Those were cavernous, a little bigger than a crown vic interior, towards some of the lincolns.
37.5Kwh X $.15 (current Entergy rates when factoring miscellaneous fees) = $5.625 per 100 miles. As far as room, you can store batteries in the engine compartment because the press is claiming a "transmission free" car. Additionally, the Toyota Prius makes good use of the back seat for storage. Although, I would be happy driving a two seat Mini Cooper that has a large trunk compartment. One problem that I think Mini will find is that the batteries tend to heat up during use and charging. Keeping the batteries batteries cool will be a challenge for them. In fact my own battery charger overheats a Group 31 AGM battery after two hours of charging and has to cycle back to protect the battery from "cooking itself". For more details and to see the basis of my calculations visit: Idaho National Labratory -Advanced Vehicle Testing Activity For a direct comparison, look at this electric S-10 made my Cheverolet. The truck used a 27.17 Kwh NiMh battery bank and had a range of 93 miles. Dare I ask why GM does not just restart making these trucks? Did you know the truck sells for $27,000 used on Ebay? Electric S10 Details |
WOW!!!!!
that makes the 50k not look so bad. still a little rich for my blood (not to say that it isn't worth it) hopefully the price will come down in years to come. either that or I can maybe get a used one in a few years. |
Lithium polymer batteries could easily provide that kind of range within that much space. |
Well the power to mass and volume ratio for lithium batteries is about 8 times that of lead and comes in small cells that can literally be packaged up to fit around anything. I doubt they need the sill space or other unusual places, but they should be able to take advantage of every last square inch in the usual places. Their real obstacle most likely is temperature control.
Meh, make the A B and C pillars into heat pipes and radiate it off the roof :D
