Need Help With ECU for a JDM D15b non vtec engine
Here's my situation. I picked up a 92 Civic CX hatch with the JDM D15b motor installed. My understanding is that the stock ECU is a p05. I've called different places such as JDM engine importers and they can't tell me if it's a p06 that's needed. This car is a 5 speed and the car was taken here to the local state ref here in Los Angeles, CA. Car passes all emissions with no problems, but the timing is off.
He recommended to either adjust the pulley or change the ecu. Which is the right thing to do? |
Can you take a picture of the engine? How many wires on the O2 sensor?
A P06 should run the car fine if its a non-vtec engine thats what came in the USDM DX civics etc...which timing is off the cam or ignition timing? Before going to replace the ECU try the simple solutions...look for the TDC marks on the crank pulley and cam gear and make sure they are lined up, adjust as needed, the look for the ignition timing marks on the crank pulley (should be 3 line in a row) now take a timing light and look at the mark on the Timing belt cover and see if the center mark on the crank pulley is in line with the triangle on the cover...loosen the distributor and rotate it as needed till you have the ignition timing marks in line....
check those and that should solve your problem... |
