If the TPS is the only way the ECU knows you're at full throttle, then hacking that with a resistor in the right place might work... unless the ECU figures it out and faults it.
You can run a welding torch on Brown's Gas. Can you run a welding torch on water vapor or steam? |
The Canadian Hydrogen Energy Company guarantees a minimum of 10-percent improvement for diesel trucks using their hydrogen fuel injection technology, (which is really HHO gas). Results are likely more since this is a minimum.
