The Beast's airdam extension is installed! **Pics included**
Ok, after listening to everyone talk about air dam extensions and then looking at collegekid01's airdam extension on his Volvo I decided to follow his lead...
I went last week to a U-Pull-It junkyard and got an airdam off of a 2wd Chevy Tahoe (so it didn't have the cutouts for the towing/recovery hooks). Cost: $10. I paid special attention to save all of the bolts and mounting hardware from the truck I removed it from. I rinsed most of the junkyard mud off of it this morning, and then removed all of the bolts and clips from the (new) airdam. I then laid all of the bolts out so I knew exactly where they were going. I used a 3/8" drill bit to drill holes in the bottom of my truck's airdam, and installed the clips onto my airdam. I then used a smaller drillbit and drilled matching holes in the bottom of the second airdam. I then bolted it on. I imagine once I get the red clay residue off of the second airdam it will be less noticeable. For $10 it can't be beat. -Jay Factory setup: https://www.fuelly.com/attachments/fo...3be3f04b4b.jpg Test fitting a bolt onto the bottom of my factory airdam: https://www.fuelly.com/attachments/fo...91a34518cf.jpg The "new" airdam laid out underneath the original one: https://www.fuelly.com/attachments/fo...bdba37cf99.jpg The following are pics of the finished product: https://www.fuelly.com/attachments/fo...78b128cab9.jpg https://www.fuelly.com/attachments/fo...14c6d3a5ae.jpg https://www.fuelly.com/attachments/fo...a0fe218124.jpg Again, once I clean it up I'm hoping this will look pretty close to stock. Does anyone think that I should make pieces to fill in the space for the recovery hooks, and the access holes in the bottom piece where you accessed the mounting bolts for the chrome bumper? -Jay |
Test it first to see if this is worth keeping. If yes, then any sort of covering or filling agent can fix those holes.
-Jay |
highway miles will tell the tail. also you could always paint both of the airdams so that they match. this would involve some time and effort but could be worth it. this would also blend in any filler you use if you chose to cover the holes
-Jay |
4 Attachment(s)
I didn't think about that stuff. does it really work? I guess it does. I have never really had a use for it.
on a related note: I am working on "PROJECT WIFE" it is probably the hardest thing for me. I am trying to get her to care. she is even more picky than me about how her car looks. I spent about 3 hours today making her grill block and I think it looks pretty good. I made it out of clear plexi glass to cover her upper grill. it is hard to see in these pics but that is more the point. more than anything, it is just shiny when the sun hits it. I may end up painting it black. time will tell. you can see the black wire ties that I used to hold it in place with. and I cut out a hole for the honda symbol to come through it for a more custom look. there again, trying to make it look semi-stock |
-Jay |
Jay and BEEF, both looking great.
Jay, I'd definitely do something about the color and fill the mounting holes on the junkyard one. It may be difficult to do anything about the recovery hook holes on the OEM one. |
-Jay |
I have always thought that fuel efficient mods can look good depending on how much time you are willing to put into it.
I want good mileage but I want to look good doing it too. jay, can you just take the recovery hooks off and coroplast the hole or do you need the hooks? a grill block would do you good too. |
