Kill Switch 95 CIVIC
2 Attachment(s)
Just installed a kill switch in my civic using the post from ajohnmeyer in the DIY forums. Thanks for the detailed info & photos. I did however change the location of the switch to the gear shifter & while I had the console out also installed a starter switch. I used a regular toggle for the kill, & a momentary for the starter switch. Killing the engine with a flick of the thumb & restarting it with the middle finger is way better that using the ignition. Check out the attached photo.
