Hello, new guy here.
Hi all,
Ok I have been thinking about this for a long time about making upgrades to my vehicles in order to increase gas mileage. Obvious things are, better free flowing Air intake, better exhaust perhaps a header. I have two vehicles, a 2002 Toyota Tundra V6, which contrary to publisized mpg get much better gas mileage than my friend V8 of the same make, model and year. Our second Vehicle is a car, a 1998 Toyota Camry, and I hope to get it up over 30 mpg soon, and that shouldn't be too hard as it gets as much as 28mpg just the way it is. My dream would be to get it over 40mpg, but I don't know if that is even possible with the current engine. I have experience in rebuilding engines, doing many performance modifications myself, so much of this stuff should not be too difficult for me. I just need to talk about it and benefit by others experience. I have in the past tuned engines to get their best gas mileage at a specific highway speed, by cam timing, port and polishing heads, valve size increase and so on. The thing I need to update myself on is how to work with the electronic sensors and computer stuff. Thanks in advance for you help. Terry |
terry,
if I were you, I would start with a scangauge. this device works on all 1996 and later model vehicles and tells your gas mileage in real time. this will also help you adjust your driving style. also you can air up your tires to max sidewall pressure and block off your front grill. that should get you started in the right direction. |
That's not to say that you can't do any modifications to help; indeed, with your considerable engine work experience, you may be able to do something useful. Look for other threads, there were a couple good threads in the past month or two where people talked about building an engine for economy. |
