CRX HF Tranny Question
I am placing a d15z1 (vx) engine in my 90 DX hatch. I have access to a CRX HF tranny, '91 I believe. Will I be able to use the clutch, linkage, torque converter, etc. from my DX , or will I need to get this from another car?
I'm not sure about compatibility, but you shouldn't need a torque converter :)
Seriously, you can put both cars into autozone.com and cross reference the part numbers. |
Yes, everything is the same, but like Erik said, no torque converter. Thats exactly the same swap I did.
If your hatch is already manual it should be an fairly simple swap. The trans should bolt right in. As long as the tranny's not an 87(maybe 88 not sure) or older your fine.
