CX to VX
I just bought a 1995 CX.
I have a D15Z1 jdm (assuming VX) economy engine coming soon. I need an ECU and a wire harness for this new D15Z1 VX engine and having difficulty finding what will actually work. Will another ECU and wire harness work? I've been reading so many different forums to find answers but it is actually causing more confusion. Can anyone help me? Thanks Michael |
To do the swap properly you will need a VX ECU P07, it will also be best to get the VX engine harness but you will still need to do some additional wiring, the VX has a 4th plug on the pass side shock tower which has the wires for the 5-wire O2 and the EGR...there is also an additional plug for the EGR control box which is mounted on the firewall in the VX...check out my build thread there are some links and info in there that might help you out, feel free to ask any questions...Matt
Thanks,
I'll check out your build |
Where can I find your build thread? I am in the middle of this build as we speak.
https://www.gassavers.org/showthread.php?t=8269
Just put the link in my sig to make it easier for you guys ;) |
