vx owner wants more mpg!
well a cx to vx converted owner wants more mpg!. i have had the vx swap in for almost 600 miles now and i get around 44 mpg mainly city driveing. and that is driving with a lot of angry people behind me shifting below 2500rpms coasting down hills. 55psi in the tires with vx wheels and the intake turned to the radiator.
I try my best to stay in lean mode at all times. and driving like there is a egg under the gas pedal. call it greed but i want more i want to break 50mpg so bad!. should i turn the car off at lights and restart when green? should i shut it down coasting? and restart? i am willing to try just about anything except crazy aero mods besides a grill block thats on my to do list. thanks in advance! |
50 mpg/city, you will get that with a hybrid, 44 mpg in city with a VX is exelent.
Do some highway, or travel less if 44mpg is not enough. |
most of my driving is 75% atlanta city driving 25% hwy. i am going to try shutting it off and lights and coasting and compression starting when coasting. 44 mpg is ok. but i see several vx owners claiming as much as 55mpg!
cems70 are you really getting 56.49 mpg out of a dx!! slaps forhead! what am i doing wrong!
I've really never seen any VX owners claim over mid-40s for city driving.
The VX doesn't have the best gearing for city driving I don't think. The best I have ever gotten on non-highway driving in my VX is lately when I've gotten 43 mpg in the heat of summer and going right around the speed limit. Good luck with it! |
Increasing power increases your city mpg. But just about anything you do to attempt to increase power in a VX does more harm than good. A turbo and a recalibrated ECU would be your best bet, but it would be a costly conversion not likely to ever pay for itself. Still, in theory, you'd be naturally aspirated 90% of the time, but the boost would be there when you need it and could help you get up to cruising speed quicker. Then back off the throttle and the load will drop back down again.
Nothing wastes gas more than going up a steep hill with a weak engine. |
ok guys i am doing something seriously wrong! i just filled up and i got 35 mpg this tank!!!!! and that is driving very slow shifting a 2500! and some eoc! god what am i do in wrong!!!
