09-17-2014, 06:46 AM
How to change the date (and time) in v2.6?
iphone 4s, iOS 7.1.2, Gas Cubby 2.6
How does one change the date? I can change the month and I can change the year with the little + and -. But not the actual date, or time for that matter?
Used to have the spin dials to change the date and time. What happened? Would like to add my data, but can't because of this issue.
09-17-2014, 06:49 AM
Yes, unfortunately the latest build had a bug that removed the date option.
I can confirm as of this morning our test build has restored that. We're still checking on a few things but will be pushing an update out ASAP.
Thanks for your patience!
09-20-2014, 06:45 AM
When do you anticipate that the update to fix the date will be released? I'm sitting on a stack of receipts waiting to be entered!
Thanks....
Paul
09-21-2014, 02:36 PM
Out of desperation, I discovered that yuo can manipulate the date and time by sliding up and down in the blacked out area beneath the month and year selectors. Picture an odometer (which is how it is modeled) and slowly slide up or down, accordingly. You'll get it with some patience. And you can always edit it. Good luck!
09-21-2014, 07:25 PM
I noticed a bug with the date field as well. I found a receipt dated 9/12/14, tried to enter it, then the system gave me a error stating that the entered receipt mileage is not greater than the last entered mileage.
I am like, I know that, but on 9/12 it was fine. The system did allow me to ignore the warning. So a possible work around? delete the last 3 to 5 fills, and re-enter them? (i though out the reciepts once I enter it.)
09-22-2014, 01:35 AM
Country: South Africa
Hi Guys
Yes have this problem too. Only with this I also cannot edit any entry - be it fuel or service. When you tap on the entry it just takes you back to the phone main screed (Iphone 5S).
O, and the export is also not working.
Thanks Loki - at least i can change the date.
Hopefully they will fix this soon - I really value my Fuelly - but this is slightly frustrating ;-)
09-22-2014, 06:16 AM
Originally Posted by Hannesvz
Hi Guys
You're welcome, Hannesvz. The other crashing issue is a known problem which is addressed here: http://www.fuelly.com/forums/showthread.php?t=16845
09-22-2014, 11:08 PM
To all in this thread-
If you haven't already, please update to v2.7 and report any bugs here: http://www.fuelly.com/forums/showthread.php?t=16883
Thank you!
