10-19-2007, 03:48 AM
Originally Posted by dogncatboy
Here is a link to the one I just installed.
http://cgi.ebay.com/ebaymotors/ws/eB...173410075&rd=1
It seems to work just fine. My car had the O2 sensor code prior to installing and has since not thrown any codes. If it is important, I can check the color of the wires for you after the sun comes up.
It would be very helpful in light of what several people have said about the blue wire.
my wires are blue, yellow, gray, white and black.
Thanks!
three stripes the charm!
10-19-2007, 06:06 AM
Junior Mint
I also have blue, yellow, white, gray and black wires. I don't have a CEL on and no codes. I did have a O2 code prior to swapping it out, none now. Car just came back from mechanic and it seems to all check out OK. I've put over 1000 miles on the new sensor with no ill effects so far and the best mileage to date, 46mpg last tank with timing belt off 1 tooth.
... D'oh!
10-19-2007, 06:11 AM
Junior Mint
I just found this online, don't know if its true:
NTK L1H1/L2H2:
The L1H1 sensor was originally used by Honda in their 92-95 Honda Civic 3 Door, 1.5 VTEC OEM Part# (36531-P07-003). The L2H2 sensor is NTK's new sensor revision, higher quality, more rugged design and is 100% compatible with the L1H1. These two sensors are fully compatible with the M-200 controller.
Original post is HERE
BTW, the post says that the Bosch sensors work too... D'oh!
I also found this which seems to confirm the above:
The L1H1, L2H2 & NTK-VW sensors are NTK/Honda UEGO wideband pump cell sensors. The name UEGO is traditionally associated with this range of sensors, and stands for Universal Exhaust Gas Oxygen. They were co-developed by Honda & NTK (the speciality ceramics division of NGK) and first appeared in the early 1990s on Honda 1.5 Litre engines. There's some more information relating to the older Tech Edge 1.5 unit and the L1H1. They predate the Bosch LSU sensor but, apart from the higher price Honda seems to want to maintain, are still good sensors. The L2H2 is the updated L1H1 and neither are sold by Tech Edge. Just to confuse you, Bosch source the L1H1 sensor from NTK and package it as their 13246 sensor.
This info comes from HERE
... D'oh!
10-19-2007, 10:50 AM
Cool, man, thanks. Maybe I put it in this weekend!
I have a question for you. If you were to accelerate slowly from low RPM, particularly in gear 1, 2 or 3, would your car stutter, lurch, stumble, hesitate or anything like that? My car is still doing that. Did it ever do this with you? Did you notice any difference in how the car drives since you put in the new o2 sensor?
10-19-2007, 12:36 PM
Junior Mint
Yeah, I had issues like that. I changed my O2 sensor and plugs at the same time, so its hard telling if it was the actual culprit tho.
... D'oh!
10-19-2007, 04:25 PM
http://www.gassavers.org/showpost.ph...2&postcount=16
Here is the one I order from Global Technomitive on e-bay, and it work great. My FE is incredibly better. No CEL and no problem.
It as the NTK stamp on it and 36531-P07-003 sticker on top.
92 Mitsubishi Galant VR-4 4G63 A/T AWDTturbo 12.122@112.9 mph 0-60MPH:3.6s 50-75MPH:2.4s ,2x 92 Honda Civic VX (4.7l/100km)
Gone in 12 seconds GO FAST WITH CLASS, DON'T USE NOS!
10-19-2007, 08:02 PM
right plugs helped my car a lot but did not solve the problem completely. So you don't have those issues anymore?
10-19-2007, 08:09 PM
Here is what mine looks like:
NTK JAPAN engraved in the metal and right below that it has a blue band that has the following written on it.
HONDA 36531-P07-003
Yay
10-19-2007, 11:16 PM
#19
HONDA 36531-P07-003
Yay
Is that the new $79 O2 sensor you're talking about or the one that is on your car now?
Gary
10-20-2007, 06:31 AM
#20
that would be the new $79 one I bought.
But good point, I will compare it to the old one.
