04-02-2007, 12:37 PM
'92 Honda Civic VX h/b
I have '92 Civic VX h/b 1.5 manual (engine D15Z1) 174K miles
My problem is: Will run fine, then idle REAL low, almost
stalling. The Check Engine lite comes on...i've coded it, i'm getting 9
& 48. called dealer code 9 isn't a free standing sensor, its a
component IN the distributor. Can I , should I try replacing the rotor in the
dist. to see if that helps?? I don't think its that, as the previous (and first owner) just replaced that about 1.5yrs ago.
I'm thinking it may be my 02 sensor,(code 48?) and thru searching here, have found some sources for acceptable (by no means good) prices on the 5 pin part L1H1.
also...does My engine have an idle adjust screw? and if so, where is
it? I'm a mechanically challenged female. Any help (in ENGLISH, not
engine-ese) would be greatly appreciated.
I'm also getting really HORRIBLE mpgs....like 30mpg avg on tank, and I
do 75% hwy driving. My '94 DX h/b 1.5 manual w/ 212K miles gets about
36-41 mpg on avg per tank...and is what i'm using as 'comparison' for
mpgs vs. the '92.
The previous owner has kept meticulous service records, done ALL scheduled maintenance as outlined. I haven't checked the sooty-ness of the plugs, and hopefully they're the right ones for the VX (i'll check to see)
I've also noticed it EXTREMELY powers down going up hill in comparison to my '94 DX.
The prev. owner still has the window sticker in all his paperwork and it states it's a vtec-e engine, but the engine itself does not have the words vtec on it.
Thanks for all or any answers
'92 Civic VX h/b 5spd 302K
'97 Civic DX Sedan-auto 125K
'01 Civic LX Coupe 5spd 112K
04-02-2007, 12:53 PM
I believe Code 9 is your top dead center sensor. If shot, your engine basically will be confused when to fire the ignition which would explain the idle/power/,mileage issues you are having. UNfortunatley, I think you have to replace the distributer to fix this, but am not sure about that. I would check the dealer to see if you can just replace the sensor. It is possible that having the timing out this far could through the mixture so far out that the O2 sensor code could get thrown, so I would fix the distributer issue first, reste the ECU, and see if you still get an O2 sensor check engine light.
04-02-2007, 12:56 PM
if you need to replace the o2 sensor, get one on ebay. search L1H1 and get the one for like $175. Much better than the stealership.
likewise, you can get a used distributor fairly cheap on ebay too. Just make sure it's an obd1 vtec distributor. I'll have to check to see what that code is before I comment more on your distributor problems.
As for the idle screw, there is one and you can adjust it.
If you open your hood, you'll see a long black plastic tube that leads from the airbox to the throttle body (air intake hose). On the throttle body there is a wheel that is pulled by a wire. The wire is attached to your gas pedal. Have someone push it in and out to see what is moving.
Anyway, where the wheel rests (when the gas is not being pushed) it will land on a screw. The screw is probably upside down, so it might be hard to get to and see, but it's there. if it's not there, there will be a hole where a screw once was. that's your idle adjust screw.
I personally think that a new o2 sensor will do wonders for you. You should notice a big increase in MPG, and it's probably also affecting your idle. the d15z1 is heavily reliant on the o2 sensor.
04-02-2007, 01:08 PM
Wow. Thanks for the replies guys.
My mechanic (shade tree honda/volvo guy) doesn't seem to think the code 9 is causing my LOW IDLE to the point of almost stalling. I have a receipt from a Honda dlrshp where the entire dist. was replaced about 1.5-2 yrs ago, and then after that the cap & rotor again. The 1st owner kept meticulous spreadsheet repairs & all receipts!! I just can't see where that whole unit would be shot again already??? I am soooo happy about finding my 3rd civic, and the one I wanted to boot.
Now to just get the mpg's where i know they can be, and get the darn CEL to go off......
I'm thinking i'll go ahead & r&R the o2 sensor, and see what happens from there.
04-02-2007, 01:19 PM
If you have a code 9 you need to replace the distributor, If you shop around on honda-tech they are not too expesive, I sold one for 45 bucks once,
04-02-2007, 01:35 PM
I bought one for $10 once on ebay.
04-02-2007, 01:56 PM
I got the one I sold for free attached to a free cylinder head! And I sold the cover to frank! I still have a d15b7 head if anyone wants it,
I win though...
04-02-2007, 04:10 PM
anybody? anybody? I just checked ebay at distributor king store, and he doesn't have any listed. thats the site with multiple thumbs up given at honda-tech.
anybody got one laying around in the corner of their garage?? if only....
I found this one on ebay...i tend to doubt listings as to fitment (that and it's all greek to me)...can anyone shed light on if this one will fit???
http://cgi.ebay.com/ebaymotors/Distr...QQcmdZViewItem
04-02-2007, 04:59 PM
Looks like the TD42U is the one to fit a VX. The link below is for ones you can get on autopartswarehouse.com. As you can see, the Ebay one is a good price. It also looks complete, meaning it comes with the ignitor, cap and rotor.
They are easy to put on (three bolts and a few electrical connectors), and they only go on one way (the slot in the cam is offset a little so you can't put it in 180 degrees out), but you'd need a timing light to set the timing correctly. If you've never done this before, I'd recommend saving the $ to have someone put this in and buy a timing light for $25 if you don't have one. I'd also get new plug wires and new plugs while I was at it.
http://replacement.autopartswarehous...ibutor&dp=true
04-02-2007, 05:03 PM
You can also search for d16z6 distributor as it is the same as the z1 dizzy. Where do you live? A member may be willing to lend a torquing hand?
Thread Tools |
Display Modes |
Linear Mode
