94 VX valves - Need adjustment? - Fuelly Forums
Old 07-05-2008, 09:26 AM   #1
VX with close to 300k miles, picked it up a month or so back. I am going to replace the timing belt and have done a lot of other general service to it like fluids, plugs wires cap, coolant flush, fuel filter, injector cleaner. The valves seem really noisy. Is this common to these 1.5L engines?
jshelton441 is offline   Reply With Quote
Old 07-05-2008, 09:34 AM   #2
Danronian's Avatar
From my experience these motors have a lot of whine in the valve train but I think it's mostly due to the roller rockers. The factory does call for the valve lash to be adjusted quite often.
Old 07-05-2008, 09:14 PM   #3
GasSavers_Ryland's Avatar
I believe the shop manual tells you to adjust the valves every 2 years or 30,000 miles, although on the 4 Honda Civic's I have owned the valves have never been very far out of adjustment, Honda motorcycles seem to fallow this trend as well of telling you to adjust the valves but not needing it, but with 300,000 miles it does seem like something to check, and that timing belt should be done right away as well! every 100,000 miles is a good idea.
Old 07-07-2008, 10:34 AM   #4
Loserkidwac's Avatar
Send a message via AIM to Loserkidwac
My VX was a little noisy and so was Dan's both of ours had similar miles on the motors, I am gonna check the them when I swap my D15z1 into my Del Sol, download a HSM (Honda Service Manual) for the 92-95 civic it shows you have to check them its very simple just need a box end wrench a flat head and a feeler gauge to check and adjust them...
MPG Noob
03 Mazdaspeed Protege
91 Honda CRX Si
95 Honda Civic VX *RIP 5/20/08
94 Honda Del Slow D15z1 Swapped
Loserkidwac is offline   Reply With Quote
Old 07-07-2008, 03:50 PM   #5
If your going to replace the timing belt, I would recommend that you replace the water pump as well. You have to remove the timing belt to replace the water pump and if the engine has that many miles on it, then the water pump is almost as highly a potential problem as the timing belt.
Old 07-07-2008, 04:26 PM   #6
The book says 12 months/15,000 miles. Although when I checked mine recently, they needed very little adjustment. And I think they hadn't been checked in a long time, maybe never. So I agree with you that they probably tend to not need as much attention as what the book says.
The book says 6 years or 90k miles.
Old 07-07-2008, 05:57 PM   #7
I would add the timing belt idler bearing since your in there and its cheap. i adjusted my valves and it was amazing how much noise went away when I tightened it up. it is really easy to do a valve adjust on these little guys. Buy a new valve cover gasket while you are at it too. 12 bucks or something.
mini-e is offline   Reply With Quote
Old 07-07-2008, 06:41 PM   #8
They seriously didn't use hydraulic lifters on those engines?
- Kyle
Old 07-07-2008, 07:30 PM   #9
It's rather hard to do hydraulic lifters with an over head cam, much easier to do with out of date push rod engines, with an over head cam there is much less weight being pushed around, less to wear out and with the design that Honda uses even tho they tell you to adjust them every 15,000 miles my civic hadn't had them adjusted in 100,000 miles when I bought it and the only reason I adjusted them at all when I checked them last was that I had the tools in my hand.
Old 07-07-2008, 08:12 PM   #10
suspendedhatch's Avatar
I wouldn't mess with a high mileage motor. Just get a low mileage JDM equivalent and use that one for spare parts. You can get one for less than $500. How much to rebuild that engine?
Valves should be adjusted once a year.
Turbocharger Market 2010 ~ what does it mean? 44mpg by 2010 General Fuel Topics 1 03-01-2008 03:35 PM
A new idea for belly panning? Snax Experiments, Modifications and DIY 0 02-16-2008 07:30 AM
Lightweight starter batteries Greybrick General Fuel Topics 6 02-02-2008 02:17 PM
Saturn idle RPM changing according to speed Fourthbean General Maintenance and Repair 5 09-25-2007 09:15 PM
