96 Nissan Pick Up problem - Page 2 - Fuelly Forums
Old 12-24-2007, 04:19 PM   #11
Originally Posted by Erik View Post
My 92 240SX has the same engine and uses a mass air flow sensor to calculate the A/F ratio. I've heard that the tiny wires in these air flow meters can become "contaminated" and sometimes need to be cleaned with a special solvent. I've never had any problems with my air flow sensor though (250,000 miles on the car).
As was already suggested, you should double check the vacuum hoses and also that the air snorkel has no cracks in it between the intake and the air flow sensor. Any cracks/leaks would cause an overly lean mixture.
thier not really tiny wires btu mor elike a screen type of thing. and yes they can get clogged and corrosion can build up. after 250K it cant hurt to clean it with the spray.
Old 12-28-2007, 02:02 PM   #12
lovemysan's Avatar
Just remember something about my old truck again. The IAT sensor connections break easily. They usually break inside the connector. The IAT sensor is located on the bottom of the breather box on the passenger side of the throttle body. I recommend you check the wiring. I can't remember how I fixed it but I think I found a similar connector at a yard and spliced it in.
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 12-29-2007, 09:57 AM   #13
IAT Circuit malfunction
I had to replace my EGR valve because it was stuck, I took the opportunity to check all of the vacuum lines and replace one. After replacing the EGR and the downstream O2 sensor the truck ran better, and worse. It would not buck and heave like before but it was acting like there was a vacuum leak somewhere. It would idle fine, then stumble and run rough, then idle fine again. It would also do this through the rpm range sometimes.
I just ran a diagnostic which told me the IAT circuit was not working. My book has nothing about IAT and I was about to post on here to find out if that was the intake air temp sensor. There was a second code telling me the system was running too lean but that may be related to the IAT circuit. Thanks guys!
edit: The mass airflow sensor was cleaned earlier this spring but I'll double check it again. It was contaminated with filter oil from my K&N filter, one of the reasons why I switched to the Secret Weapon intake. The filter does not need to be oiled and filters better than the old K&N.
dm1333 is offline   Reply With Quote
Old 12-29-2007, 04:39 PM   #14
lovemysan's Avatar
Well the IAT sensor is mounted in the bottom of the oem throttle body "hat". I'm not sure how the sensor would be mounted for the weaponR setup. It should definitely be monitoring air temps inside the CAI. Its very rare that the sensor fails. Usually its the wiring or connector. Check my the above post.
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
yo JUGRNAUT Introduce Yourself - New member Welcome 81 06-20-2007 07:26 AM
Things To Look For When Buying A Civic Hx panamacolin General Fuel Topics 9 06-06-2007 08:43 AM
Vote for best license plate caption! Matt Timion General Discussion (Off-Topic) 14 09-28-2006 05:06 PM
Modify O2 sensors zpiloto General Fuel Topics 25 08-04-2006 11:11 AM
