12-16-2009, 10:51 PM
Differential Explained
12-17-2009, 06:11 AM
I've seen that one before...it really is great. The meat starts at about 3:30.
[yt]K4JhruinbWc[/yt]
12-17-2009, 06:35 PM
Great video...breaking down the principle of the differential gear into easily understood pieces.
I guess they hadn't invented the driveshaft tunnel yet...
12-17-2009, 11:34 PM
the wha? the model T had a driveshaft tunnel. my AA does. god that thing is a beast! axle and tube weigh prolly 900 lbs of pure AMERICAN steel AND its a worm gear drive rearend.
i first learned of how a differential works from believe it or not but legos (actually the Technic side of legos)
12-18-2009, 08:07 AM
How about the Torson differential . . . that was a major improvement. My BMW R100S has a swingarm with the shaft inside it to the rear end but it is not a differential. It does however use an offset from center pinion to drive the crown gear so it is sort of a worm drive. After I teflon empregnated the gears it became much easier to bump start in 1st gear where as before the rear wheel would lock up.
12-18-2009, 05:27 PM
I think you are thinking about the torque tube, which was a tube which enclosed the driveshaft. IIRC, Model Ts, Model As, and a bunch of other older model cars used that. I was talking about that hump down the middle of the floor on RWD cars...that place where you don't want to sit when you have 5 or six people in a six-passenger car...
12-19-2009, 11:21 PM
ahhh yea lol. yea that tube came about because cars were getting lower and faster (better handiling and lower due to better road imprevements. gotta remember T and A days roads were dirt and commonly got washed out/rutted. had to have high ground clearance and be rugged.
even up into the 50's roads were dirt (some still are)
12-21-2009, 05:28 AM
That hump is still there for the exhaust pipe now even on front wheel drive cars.
12-21-2009, 05:42 AM
I think the hump is also structural to stiffen the floor.
12-21-2009, 08:38 PM
yea part exhaust routing part structural (or could be structural and decided to route the exhaust there
Thread Tools |
Display Modes |
Linear Mode
