How hard is it to replace PCV valve?? And should it be replaced? - Fuelly Forums
Old 12-09-2005, 01:31 AM   #1
Compaq888's Avatar
How hard is it to replace it?? Should it be replaced, my car is 63k miles and it was never replaced.
I'm trying to replace anything that has to do with fuel economy that needs to be replaced.
Old 12-09-2005, 05:23 AM   #2
GasSavers_DaX's Avatar
It's generally pretty easy.
It's generally pretty easy. Take it off the car and shake it - if it rattles, it's good, if it doesn't, clean it with brake parts cleaner unitl it does rattle, or replace it [they're only a few dollars]. One thing I also recommend replacing is the hoses [both upper and lower] that attach to the PCV valve, especially if they've never been replaced before. These hoses probably not only are brittle, but caked to hell on the inside with crusty oil residue, reducing the inside diameter. I'm actually doing this today, along with many other things to try to get my car to pass emissions.
Old 12-09-2005, 06:56 AM   #3
Compaq888's Avatar
My car passed the second
My car passed the second time but I just want to do all the maintenance before all the parts break that way my car won't break down. The part is like $8. I plan to do it with other stuff at 75K.
So far I had the air filter, fuel filter, transmission flush, radiator flush, distributor cap, spark plugs, distributor rotor, spark plug wires, synthetic engine oil, and bad rim changed.
I'm trying to find all the worn out stuff.
Old 12-09-2005, 07:36 AM   #4
kickflipjr's Avatar
I replaced mine. I got the
I replaced mine. I got the part at wal-mart for $1.99 i think. It took less then 5 min to change.
2008 EPA adjusted:
Old 12-09-2005, 09:55 AM   #5
Compaq888's Avatar
I'm getting a guniene nissan
I'm getting a guniene nissan part. I don't want to short myself and then be complaining stuff is broken.
Old 12-10-2005, 08:47 AM   #6
Dax, i have it on good
Dax, i have it on good authority that just becuase the part rattles does not mean that it is okay, that just means it's not clogged. Honestly, for the price, and ease of change, to replace it is good peace of mind.
chesspirate is offline   Reply With Quote
