seeking aero advice - Fuelly Forums
Old 12-20-2007, 05:14 PM   #1
seeking aero advice
I have a 2003 Saturn LW200 2.2 4-speed auto. I am trying to squeeze every mpg I can out of this car.
Here's what I have done so far:
warm air intake (I may convert it to a hot air soon)
2.25in exhaust from engine back
lowered suspension
((I used to race this car so these were done for power not economy))
upper grille blocked (I'm planning a lower grille block soon)
small lip spoiler (trip strip) on tailgate
tire pressures at 44 psi (max rating on sidewall)
I guess my questions are where to go next and have I done any aero damage with additions (such as the lip spoiler).
I am looking at a belly pan. The window screen thing has my complete attention. I am also looking at fitting a hard tray between the bumper and radiator support so the air sent to the radiator goes there and not anywhere else.
I am hoping to see 40+ mpg
Old 12-20-2007, 06:16 PM   #2
SL8Brick's Avatar
Re: the rear lip spoiler...
I have one of these on my Volvo wagon...http://www.jcwhitney.com/autoparts/P...001926/c-10101
I have the 1" high version. They're very flexible and can be easily bent to contour to a rounded rear roof line. They can also be profesionally painted to match. Personally, I like the practical benefits and anti-lift characteristics of the rear lip when applied to a two-box...but I'm sure there are others here who will disagree with that.
SL8Brick is offline   Reply With Quote
Old 12-20-2007, 06:25 PM   #3
yep thats the one
Old 12-20-2007, 06:30 PM   #4
SL8Brick's Avatar
Originally Posted by philip1 View Post
yep thats the one
Any close-up photos of yours?
Old 12-20-2007, 06:48 PM   #5
I'll have to get some when it's light out
this is the best I have so far
Old 12-20-2007, 06:50 PM   #6
kamesama980's Avatar
2.25" is way bigger exhaust than you want. 2.25" is perfect for my toyota 3l revving engine. Your domestic 2.4 will probably do better with a 2" (quality exhaust!!) or so unless you get the revs up. reason is you'll lose exhaust velocity and low-down torque meaning you'll have to use more gas. basically, exhaust size determines peak torque point and powerband distribution. 2.5 collector to axle to a 2.25 axle-back on my 3l puts the power peak OVER 6k rpm. 2" with cat and both mufflers put it about 4.5-5k. You want the peak efficiency to be where you spend most of your revving time: in an economy mindset, at or around acceleration and highway rpms.
Course then again maybe the ecotechs are wierd sobs and do best with a big big exhaust.
I suppose I should also qualify that it depends on how good the exhaust system is. if you use a free flowing cat and muffler with mandrel bent pipe, you'll want 2" or less. if you get regular press-bent with wrinkles, crimps, and normal mufflers, 2.25 might be necessary to make up for the inefficiency of the system itself.
-Russell
Old 12-20-2007, 06:53 PM   #7
I used to race this car incase the photo was not a total give away. this exhaust size was determined by several factors.
1. VE at 5800rpm needed flow conducive to 2.25in pipe
2. 16 valve head flows more than 8 valve
3 10:1 compression
4. Dyno results indicated a 5-7hp gain across the board
this means nothing to FE unfortunately just a loud drone
BTW: I can't remove the roof rack due to the factory installed curtain airbags.
Old 12-20-2007, 08:17 PM   #8
Here's another source for the spoilers.
Dynamically Aero is offline   Reply With Quote
Old 12-21-2007, 11:18 AM   #9
Like I said, I don't have experience with the ecotechs.
well if you're looking for 5800 rpm power, go for it. I've seen people do too big exhaust on cars and lose (usable) power and mileage because they shifted the exhaust velocity peak above redline. Drive an Infiniti G20 with open downpipe vs full ehxuast...revs great and huge power on the highway and crazy high rpms but you can't drive with it under 3k rpm. put the exhaust back on and you can chirp the tires at 2k rpm.
-Russell
Old 12-21-2007, 02:42 PM   #10
if I could I would go back to a stock cat back at least
Trying to add a car bw61374 Fuelly Web Support and Community News 1 08-17-2013 07:14 AM
Suggestions from a Newbie juha Fuelly Web Support and Community News 6 10-03-2012 07:03 AM
Yeah wont be driveing for a while Hockey4mnhs General Discussion (Off-Topic) 29 04-09-2007 06:29 PM
elg's Project zpiloto General Fuel Topics 2 03-03-2007 06:47 PM
Search feature added Matt Timion Fuelly Web Support and Community News 1 09-26-2005 02:02 PM
