tested my kammback - Fuelly Forums
Old 08-02-2007, 11:06 AM   #1
jwxr7's Avatar
tested my kammback
I needed to retape my kammback so I decided to do a test with and without it from 55-45 mph average of 2 bi-directional runs each.
Here are some preliminary results of the coast down testing.
Same test mile used for mega airdam test, 95 f, 30.03" hg, winds from west around 5 mph, no airdam installed all other aero appliances in place , test mass 1981 lbs.
With kammback = 15.86 seconds.
Without kammback = 14.14 seconds.
from 55-50 mph
with = 7.97 sec.
without = 7.16 sec.
So kammback is a good add on .
I still need to clean my hatch and reattatch the thing.
Disclaimer...I didn't follow the best testing procedures due to time and space limitations (and some laziness). I should have posted this in the experiments section but it wasn't proper enough IMO.
Old 08-02-2007, 11:51 AM   #2
Ooo, nice results. Did you put them in the coast-down calculator to see what kind of Cd reduction that implies?
Old 08-02-2007, 12:04 PM   #3
brucepick's Avatar
Can you post a pic here of the current configuration? I think you just have the side pieces with a hollow center - correct?
I don't think I have the nerve to build one for my "brick" - it would be huge, and would have to have a clean join to the main body as well as to the liftgate. But I'd like to see yours again in this thread.
Old 08-02-2007, 12:06 PM   #4
jwxr7's Avatar
thanks bill
No, I haven't got that far yet. Too busy at work today.
Old 08-02-2007, 12:51 PM   #5
SL8Brick's Avatar
jwxr7 - I like it. At first I thought it hindered you rearward vision, but I can see by your pics in the garage that it really doesn't block it too much.
brucepick - Your correct, it would be fairly large on a 245 hatch. But you might get away with just fastening it to the hatch alone. The d-pillars aren't very wide in the back so laminar sep. would be minimal. Just an idea.
SL8Brick is offline   Reply With Quote
Old 08-02-2007, 01:09 PM   #6
jwxr7's Avatar
I just put it back on.
Sorry, the best I can do right now is direct you to my garage pics . I'm not photo literate. It is one long piece bent to make the sides and a support was cut to fit the middle. BTW the airdam in some of those pics is the 7" version which is now trimmed to 4".
I would like a better more permanent way of attatchment, but the tape works for now. I may try different angles sometime too.
Thanks, yeah It really doesn't obstruct rear view (unless you want to see up behind you ). In fact it makes a nice sun shade while parked .
Old 08-02-2007, 01:25 PM   #7
brucepick's Avatar
I'd really like to make one up. When I take off my temporary coroplast air dam I'll see what kind of gunk the duct tape leaves behind and how much of a PITA to clean it off. My car's not gorgeous but it would be worse with tape gunk residue all over.
I had a full sheet coroplast, 4' x 8'. I thought that was big enough to build nearly anything but I used it all for the temporary air dam + the belly pan to go with it. No free coroplast till electon day, dang. Plywood??? Not with duct tape. Frustration!!
Old 08-02-2007, 01:35 PM   #8
jwxr7's Avatar
I just added a couple current pics (top two) to my garage. One shows 4" airdam.
Old 08-02-2007, 01:45 PM   #9
brucepick's Avatar
Cool! In the first pic, the side view, it looks "factory"!
Old 08-02-2007, 01:58 PM   #10
jwxr7's Avatar
Now that's a compliment .
I did some more calculations. It appears the kammback improves Cd by about .05 . And average road load is reduced from 63.18 lbs to 56.75 lbs between 55-50 mph by using the kammback. (I love when i can use physics for real life stuff)
MPG Calculation knhobson Fuelly Web Support and Community News 14 04-02-2011 04:35 AM
Suggestion: Ability to have date in format DD/MM/YYYY carlosbutler Fuelly Web Support and Community News 7 11-17-2010 07:45 PM
Currency SirTK Fuelly Web Support and Community News 3 11-27-2009 12:25 AM
I got a Nintendo Wii UfoTofU General Discussion (Off-Topic) 5 11-22-2006 04:44 PM
