New member with a civic - Fuelly Forums
Old 07-05-2007, 05:33 AM   #1
Member
Hi all, just recently joined your forums in my quest for better gas mileage. I have a recently acquired 2003 Honda Civic. It's unfortunately got an automatic transmission (I really prefer MT/RWD to this econobox AT/FWD config) but at least I'm happy with my mileage (so far). I definitely want to bring my mileage up though, if I'm going to have to live with a FWD, AT, 4cyl vehicle (ugh, I just cannot state how much I hate driving a car like this) I am going to extract any possible benefits I can from it! I'm planning on doing some minor modifications to it; a transmission controller (from awshifting), lowering, a rubber air dam, etc. are in the works.
My last vehicle was a 1995 Chevrolet K1500 extended cab with a 5.7L engine, 5 on the floor and 4.10 final gears. I got an average of 10mpg throughout the lifetime of the vehicle! I could barely manage 12mpg when shifting at 1,300rpm and cruising below the speed limit (hard to do in south FL, people are terrible, terrible drivers here as a rule of thumb ).
I look forward to learning and contributing in this forum, it seems to be a pretty nice place.
varg is offline   Reply With Quote
Old 07-05-2007, 06:35 AM   #2
You're going to do great.
Old 07-05-2007, 09:32 AM   #3
brucepick's Avatar
Welcome!
Wow - you've already more than tripled the mpg's compared with the truck!
I think with an a/t one main point is to keep the torque converter locked up as much as possible - hopefully it has t/c lockup.
Also I'd definitely get a ScanGauge for real time mpg readout. It plugs right into the OBDII port in the passenger compartment. That's the first thing I'll get for my next car - only works for '96 and later since it relies on OBDII for its data.
Old 07-05-2007, 10:56 AM   #4
Sigifrith's Avatar
Welcome.
I still have a 95 C1500. Got the small V8, & SWB too, so mileage is not as bad.
Find an old VX, they are out there. You should be able to pull 50+ MPG.
[SIGPIC][/SIGPIC]
Sigifrith is offline   Reply With Quote
Old 07-05-2007, 07:18 PM   #5
Member
Thanks for the welcome everyone,
brucepick; I believe the 03 civic has a lock-up torque converter, I think all post 1990s vehicles do. I've never worked on a post 2000 vehicle that didn't... I was thinking about a manual transmission swap earlier to cure my AT problem, but when I wrote down on paper what I'd have to do, I figured it just wouldn't be worth the time, effort or money.
It's funny how a few changes in the vehicle can make a huge difference in mileage, Sigifrith, for a truck not so different from mine, you have double the gas mileage... That's very suprising. I'm guessing the differences are the lack weight of a transfer case, front diff and half shaft, the extra foot or so of my LWB and a lower final ratio.
Old 07-05-2007, 07:47 PM   #6
yea usually switching from auto to manual isnt too easy and might as well buy the same car with a manual tranny, alot less work/time/ less bugs to work out.
new link for Mobile after submit Pontiac Fuelly Web Support and Community News 1 02-07-2009 04:48 AM
Intake Air Temp resistor experiment. usedgeo Experiments, Modifications and DIY 82 07-17-2007 02:59 AM
Just got my '95 VX whychug Introduce Yourself - New member Welcome 7 01-30-2007 06:24 AM
Finally got some LRRs rh77 General Fuel Topics 4 10-03-2006 08:16 PM
