05-25-2007, 01:05 PM
Effective lean burn requires a lot more than just leaning out the mix...the civic vx has a whole load of crap done to allow it to run lean effectively, while something like the RSX will see little benefit from a simple lean condition. Wikipedia has a bit on the vx lean burn and somewhere there is an article where a few folks with a dyno made an AFR v. FE graph on an RSX and found very little improvement...
05-25-2007, 01:07 PM
Originally Posted by Fourthbean
Does a megasquirt know how much gasoline is being used?
SVOBoy -- I was introduced to megasquirt by a friend a few years ago. I always thought the purpose was to make a carbed car into a FI one. LOL
You can do it with a carbed car, just have to throw a TBI from an old chevy or something and get all the little parts needed like the TPS to hook up. Would be more work to an extent I suppose, but I would know how it all worked after hooking up every single sensor and wiring it all up.
What is involved in Lean cruise besides editing the AF ratio.
Ah, okay, I didn't know you were going to convert to FI, I must have missed where someone wrote that part,
05-25-2007, 02:05 PM
Linkz por favor?
05-25-2007, 02:07 PM
Originally Posted by omgwtfbyobbq
Linkz por favor?
Gimme a sec, I'll edit this post when I find them. I have issue with never citing unless it's graded,
Wikipedia: http://en.wikipedia.org/wiki/Lean_burn
I don't feel like finding any more detail on it, perhaps that PDF on the VX that has floated around can be dug up.
The RSX tuning stuff: http://hondatuningmagazine.com/tech/0510ht_fueleconomy/
05-25-2007, 02:32 PM
That's np, I was mostly interested in the RSX tune since I couldn't google it quickly. Thanks btw!
05-25-2007, 03:51 PM
There is code in the MS1Extra code that can do this. I want to use an MS2 which will mean modifying the code to calculate it, but being open sourced, it can be calculated and displayed. Again, it is a bit if work, but with a forum with thousands of users, I'm confident I can find the help I will need to get this to happen.
05-26-2007, 04:55 AM
Interesting reading, thanks. Not much more is needed to run superlean, but it would take a while to find optimized settings, if emissions weren't an issue to you. Have to give this some thought.
