As far as wanting high demand for oil and gas, that WOULD be a reasonable thing for an oil company to want...that is what they are in the business of selling. On the other hand, many oil companies are branching out into other energy spheres...see https://www.huffingtonpost.com/2008/0..._n_101847.html Again, oil companies, like car companies, are in business to provide a return on investment to their investors. The year I started driving, 1971, the average car got about 10-12 mpg. My Corvair got about 19mpg. Was it possible to build cars which got better mpg? Certainly. Smaller displacement motors, lighter car bodies and manual transmissions all existed in 1971. The typical European car was like this. I had a friend with a 1969 Austin America which got mileage in the 30s, IIRC. It was also the only car in the neighborhood my Corvair could beat in a race. If you remember back that far, think back to '71. If you don't, just think back to when you were about 16 or so. What car did you WANT? I'll bet you Donnas to doughnuts it wasn't a Citroen 2CV! (Personally, I was kinda partial to either a '67 Lambo, any V8 'vette, or a '37 Cord 812.) Since an hours work at minimum wage would buy 5 1/2 gallons of gas, more or less, fuel cost wasn't as big an issue as it is today. So, do you blame automakers for building and selling what people WANT? Over the years, technology has allowed us to get a LOT more efficiency from our engines. My Geo would blow the doors off my Corvair, use half as much gas, and run many times the number of miles, while holding up much better! And it's pretty much stone age technology compared to what's around now. The advances made by the auto industry in the efficiency of their products is pretty damn amazing. Imagine if these SUVs had been made in '71. Probably would have gotten 5-8 mpg, half as much horsepower, and run 75,000 miles before needing a ring/bearing job. Kinda points away from collusion between Detroit and big oil. Plus, if there were this collusion, why would Toyota, Honda, GM and Ford be building hybrids? BTW, I haven't had idiot box service for two years, where I live you need cable or satellite. Gave up talk radio about the time Limbaugh started spouting. 73 and have fun! |
So THAT'S why the smart people were able to wait until the Hindenburg touched ground, then walk off the ship! Always wondered that! |
Actually Joe Bob the most highly flammable part of the Hindenberg was the dope they used on the outer fabric covering. Its fairly easy to see that when you look at the movie of the burning fuselage.
regards gary |
Mythbusters investigated that... The fabric coating was far more flamable than it should have been, and with it being filled with Hydrogen just made matters worse.
-Jay |
Would probably have been cellulose nitrate dope, not exactly flame retardant, it's more in the vicinity of explosive.
hi guys ,can any one tell me ,,if i can put a cat bypass tube in a v6 3.4 toy,,i,m in az and cat theft is a prob,,i,m running a hho gen,no other mods ex.duct tape on grill,thankyou tundrastoy
hydrotech AND HIS HONDA CIVIC
Ok, I am curiouse, how much HHO output is your generator doing?
I have a 1996 Honda civic EX 1.6L engine My system puts out between 3.5 and 4 liters per minute. So basicly 1 gallon per minute. Anyways, I am curiouse about that, and I am also curiouse are you able to stop the car and then start it back up without the engine blowing up from the left over Hydrogen in the line and in the engine? Also, what do you have your map sensor dialed onto. I will be making a website for a chart on what people ahve all this setup as and the old MPG to the new MPG they are getting so others can copy it for that vechile. Thanks for the infomation, I hope to achive no less the what you have with your honda. my email is billman2002@gmail.com and that is my msn as well. Is it ok to just hook it up to the air intake? or elsewhere as well? |
Voltage Regulator
I have a question.
I do not want to use a PWM. as the amps you can't just set it at 20 AMPS and leave it. As it warms up, it will raise the amps, then you have to turn it down. Right now I'm using a car charger 12v 20 AMP However it is huge and really tacky, I have to convert it to 110v and and then hook the HHO unit up to that. And it is hooked up to the cig lighter lol. Anyways, I was wondering, what device can I actually use to keep the line so it wont go past 12v 20AMP? And without a PWM cuz I borrow out my car a lot and I know it will get missed up. Thanks, Will my email is billman2002@gmail.com |
That's enough HHO to boost a semi?
You need to use a relay that is triggered by the RUN position at your ignition switch. I also use a manual switch too. You control amps used by controlling the amount of electrolyte used. To use no more than 20A hot...get it to run at around 10-12A cold? |
