how long ago did you get the tires put on, how long are the stems, and what kind of wheels do you have? I ask because I've seen cracks develop in stems earlier than expected on medium and long stems (usually for steel wheels to extend past the hub-cap) because at high speeds, the stem bends outward from centrifugal force. I've also seen it from using the red/green pressure indicator valve caps (even on short stems) because they're so heavy. *this is over the course of 6 months+ tho. usually stems last 2-5 years (Depending on conditions)
Everyone is shocked that OEM Lexus rims would do that, I have no idea, I just wish I got the Alloys instead but they're always pricey used when I look. |
I have heard that a bead of hardware store silicone caulk on the outside of the bead can take care of this sort of problem- but I haven't ever tried it myself.
Re-designed maybe, but theoretically not replaced. -BC |
nitrogen has almost no oxygen, this lessens the chance for corrosion on the inside of the rim bead. no oxygen=no corrosion.
anyway, i bet the rims/wheels are cracked. |
Have you checked every par of the tire? Maybe there's a cracked from age hat allows some air to slowly escape. I was thinking maybe the stem valve might be failing too.
