RW, I'm curious to see what type of gains you'd get, if any.
-Jay |
https://www.cjjplumbing.com/Misting_Fountain_Article.htm "you can use distilled water with just a few crystals of standard table salt added. The dissolved salt will add the necessary conductivity to the water without adding the unwanted minerals." "The disk can wear out faster if the water used is highly mineralized or aromatherapy oils are use frequently." I will assume that gasoline would reduce the resonator life just as oils do. |
"i do have to say that before i got married, the most entertaining project that i built was a carburetor, and it had no floats, no valves, no jets, nothing to meter the gas flow. it did however have 2 fuel pumps, one in and one out...etc." This has been on the I-net for years. While this guys experiment with "elephant diapers" and an ammo can demonstrates that vaporised gasoline burns far more efficiently than liquid gasoline, his, and any other "wicking" system, won't work LONG TERM. He only did it for a short time. What he was doing was vaporising the lighter elements in the gas.If he had tried to run his truck for a week or 2, he would have found his 'elephant diapers' and the ammo can would have gotten clogged up with stuff that looks like coffee, smells like old gas, and won't vaporise off the wick. (Unless he had a way to return the gas in the "carb" to the tank after each run, in which case the gas in his tank would have gotten "gunked up".Gasoline is not 1 substance, in the way that say,... pure alcohol or acetone is. Its many different substances, mixed or "blended" together. Some vaporise very readily, some do not.Some of the heavier portions are hydrocarbons (derived from the original crude) and some are additives.Such a system might work if you are willing to run your car off Coleman fuel, @ $8.00-$10.00/gallon.
These "heavier" less easily vaporised fractions are the portion of the gas that ends up in the combustion chamber, as a liquid, and only vaporise after the high temp of combustion, and add nothing in terms of power to the car. Some are trying Catalyctic "Cracking", using extemely high heat, over 1000 degrees, styeam and exposure to catalysts to crack the larger heavier molecules into smaller ones, similar to what the oil company does. I am sceptical that this is practical, operating a mini refinery while going down the road.Also, no ones given me a good answer as to why, the oil companies don't do this, if its practical. i.e. "crack" all the heavy elements into lighter ones, then add cheap (heavy)additives as "fillers".Anyway, the point I'm trying to make is don't waste your time looking for mister stones, or trying to modify airbrushes, until you figure out how to deal with the heavier, less-easily-vaporised elements.Or, you'll end up with stuff that smells like old gas, and looks like coffee, in your tank, and/or fuel system. Jim |
I have to agree with the vapor type carbs leaving a useless old smelling gas in the tank. I built a "Geet Reactor" on one of my push mowers. To my amazement it would fire right up, but to use it to mow lawn was real troublesome after the tank started to get low. I would have to add a splash of new gas to keep it running. One difference with the "Geet" was they claim it converted hydrocarbons and water into hydrogen, which apparently mine didn't work as claimed.:rolleyes:
Here's some history on heated intakes.
https://seattlepi.nwsource.com/local/..._needle20.html 1959 Opel T-1 get's 376mpg in 1973 sponsored by Shell Oil You can find this elsewhere also. |
Wow- very interesting pics of the actual car from https://www.opel-p1.nl/custom/testcar/Shell%20Opel.htm
Check out the insulated engine- it looks like the carb is sucking air from the top of the valve cover. I cant imagine how hot is must get under that insulation. https://www.opel-p1.nl/custom/testcar/888.jpg https://www.opel-p1.nl/custom/testcar/999.jpg its a two speed- Chain slides from sprocket to sprocket Front: https://www.opel-p1.nl/custom/testcar/555.jpg Rear: https://www.opel-p1.nl/custom/testcar/666.jpg Front axle: https://www.opel-p1.nl/custom/testcar/9994.jpg |
that is cool some one should def try to mimic thisidea and see if it could work over an extended period i really doubt the engine life.. if its always running so hot
its funny how as more and more of these near urban ledgends (100mpg carbs and 300mpg cars or Smokey's 60mpg 300 horse power Fiaro etc.) we discover more and more why they were left to rot, and not developed further. And its got nothing to do with corporate greed and conspiracys.
Gasoline varnish (casual name for it). And fiberglass insulated engines. Imagine trying to warrentee that engine? What are the prospects of a 400 to 500 degree running temp engine having a bearing life beyond a couple thousand miles? If its running anywhere close to exhaust gas temps then it's exceeding even synthetic oil's ability to withstand viscosity breakdown. If you run an oil cooler or three you defeat the purpose of the insulation in keeping as much combustion temp inside the chambers as possible. Peak temps would be even higher, but 400 degrees sustained will soften (anneal) almost any bearing material over a long drive. Peak temps (temps at the bearings are much higher than the operating overall temp of an engine) could easilly exceed the melting point of most bearing materials. And then there's gas varnish left from vaporizing gas at high temps... Guess where this stuff sits and collects? Anywhere where the temp got high enough to vaporize it; that's where... So it's either collecting in the tank (best case for it too) or filling up the intake, or stopping up your fuel lines, or its quickly clogging up your carburetor OR your fuel injectors... The only place it will burn is inside the cumbustion chamber... And guess where that leaves vapor fuel systems? right back at square one pretty much, carbs and fuel injectors. Now I';m not saying these problems are insurmountable... Not by a long shot... vaporize the gas and inject the varnish with MPFI... but do you get a net gain when the vapor is remixed with the varnish? As an aside has anyone here ever taken apart a old worn engine or carb that sat for a long time? Gas varnish is some of the most stubborn gummy re-congealing substances ever... wash it in Acetone and it liquefies. But if you dont scrub and wipe it off fast enough, it hardens back up into a rubber cement like gel and you have to do it all over again. It even gums back up with brake cleaner! Nasty stuff |
I've read that, in plane piston engines anyways, that an engine firing gasoline runs better when the fuel enters the cylinder as very tiny droplets as opposed to a complete vapor.
