Yeah, I like the look of that.
lovemysan -
There is something really nice in the Saturn S-Series look that seems to allow for aerodynamic mods. The nose is very "soft", so to speak, and the lines are clean, so things like your engine grill block go on well. CarloSW2 |
Repete, i had taken my grill block off cause was just tied on with tape. i found some zip ties and fastened it more securely. i live near the beachs here and went to the mall and back and only time temps got up there was when stopped for a while in traffic or when i hit a few light back to back. as long as i could move temps stayed down where i liked them. this was a full grill block and only openings was the two small ones in front. it's helpfull to have a scanguage to monitor temps cause the temp gauge in dash hardly moved once warmed up.
you might want to try cardboard or somethign you can trim up easily at first to see what you car needs. |
Two other things to consider about my car. First is I generally have 300-600 pounds of load in the car. Plus I have a larger car with a larger engine. It also has to user friendly enough for my wife not to overheat the car. If I could get good fuel economy at 215f max I would be fine. I have to be careful though. |
cfg83, that was exactly what I had emant!
Well I don't frequent Sfans much. Everytime I post some good numbers up I get these people chiming in making ridiculous clames with no T2T data. Its an excellent diagnostic source though. I will be posting my aero mods. HAHA. Just to create a stir. |
Be cool to smooth out the wheel well buldge altogether in the rear so it is nice and smooth. Starts taking on the look of the EV1. I always wondered why they keep putting a lip on the wheel wells instead of like the old Jags which had a nice clean cutout.
if you car has a 190 thermostat then in summer is must get over 200 with ac running if you use it much. 300-600 lbs? :eek: |
