Eh... It makes the average intake/cylinder temperature higher because exhaust is hotter, but it reduces the peak cylinder temperature because the intake charge contains less oxygen per volume. If too much exhaust gas/heat is present, the fuel may combust before the spark fires.
Engine Additive
Also, the darn stuff comes out of the exhaust pipe already! ;) RH77 |
you are forgetting a couple of things - first the gasses will have cooled at the tail pipe and on the way back in the hose to the intake, second is the load is light when vacuum is high and that's when you need more exhost recirculated and that means low exhost temps anyway because you are not burning a lot of fuel - plus less O2 would inject less fuel and you will loose power that will require more throttle and more air and lower pumping losses . . . exactly what you want.
Check this out.
--- Another question I've been mulling over: if EGR were "manually" introduced to my engine, how quickly would it respond with correct fuel metering? Initially, would it not lead to an over-rich condition because the engine is pumping fuel based on readings from the MAP and TPS? Would an O2 sensor respond quickly enough that this would even be a feasible experiment? Does it even have enough "influence" on fuel metering to preserve stoich A/F mixtures at 20 or 25% EGR? I don't know enough about O2 sensors. I suppose the same question could be asked in terms of driving at high altitudes: "At 9,800 feet, for example, there's about 2/3 of the oxygen in the air than at sea level." - source Even if you were driving at 4500 feet, there may be 15% less o2 available than at sea level. Modern engines must be able to adjust to that, or we'd all be spewing soot driving through some of the passes in the Rockies. |
Managing EGR- What to Do?
Thanks to the inspiration I get from this site, I dug into the ECU disassembly for my car and found an interesting section. The problem is, I'm not sure what to do with it? Here's a copy/paste, have a look:
;************************************************* ******* ; ; EGR solenoid duty cycle ; as a function of rpm(column) and airVolume(row) ;Value of $00 to $80 will produce 0 to 100% duty cycle ;************************************************* ******* t_egrDutyFact #ifdef E931 RPM 500 1000 1500 2000 2500 3000 3500 4000 Load 1. $10 .byte $00, $00, $00, $00, $00, $00, $00, $00 2. $20 .byte $00, $00, $00, $5b, $56, $4c, $4d, $00 3. $30 .byte $00, $00, $00, $5b, $56, $4c, $4d, $00 4. $40 .byte $00, $00, $00, $5b, $56, $60, $5c, $00 5. $50 .byte $00, $00, $60, $76, $6c, $5f, $5b, $00 6. $60 .byte $80, $80, $80, $7d, $6e, $5f, $60, $00 7. $70 .byte $80, $80, $80, $80, $76, $68, $61, $00 8. $80 .byte $80, $80, $80, $80, $80, $60, $61, $00 9. $90 .byte $00, $80, $80, $80, $80, $78, $6e, $00 ;************************************************* ******** ; ; EGR solenoid duty cycle as a function of ECT ; ; Value of $00 to $80 will produce ; 0 to 100% duty cycle ; ; ;************************************************* ******** t_egrDuty .byte $80, $80, $5b, $4f, $00, $00, $00, $00 ECT degreesF- 186 176 125 95 69 46 19 3 -> ************************************************** ******** As you can see, this is where EGR is handled. I know where this section is located in the code, so I can change any of the bytes to adjust the duty cycle. I've searched for good articles about EGR, but mostly I seem to find basic info about what it does. As you might have guessed from the disassembly, I'm looking for reasons why EGR might be useful or harmful to FE when increased/decreased as the engine sees different loads and different temperatures. If needed I can also make adjustments to the fuel and/or ignition timing maps to optimize the EGR effect. But like I said, where do I start? If anyone out there has run across some detailed tech info about EGR, let me know. I'll keep searching too. If the code isn't clear, just ask. Thanks! Dave W. |
Load First
This is all just a guess...
Since ECT regulates the EGR as a function of emissions/warmup, that part should probably be left alone. I'd reccommend "baby-steps" in introducing small amounts of EGR in low-RPM, low-load situations and see how driveability and FE react. For example, in the $40 column of load, at 2000 RPM, add a $4f (from the engine temp byte); see how that works, and do the same for $30 and $20. Since it's an experiment, document your findings at each change, and see what happens. I would then keep adding a small amount of EGR at lower load and RPM, if it works, and maybe until it's no longer running properly or efficiently. I couldn't tell from the data, but is there a smaller amount than $4f for EGR duty (such as $3x)? You may look into that and add even smaller amounts if the larger one is too much. Good luck! RH77 |
DRW -
No intelligent statements, but here is what the data looks like in 3D : https://home.earthlink.net/~cfg83/gas...duty_cycle.jpg CarloSW2 |
