The vent is where the radiator sits on the 92-95 Civics so it is purely function over form there. I personally dislike asymmetrical styling on cars, but since I know it serves a specific function I let it go, lol. Quote:
oneinchsidehop,
I actually started a thread similar to this one where I show how I did mine (youtube vid). I will admit that mine didn't come out as good as TomO's did but I like the results. we talked about it extensively in this thread above. he was a good resource and pretty much talked me through the process (good to have internet friends). also, if it helps, I don't do body work. this was only my second attempt (counting the failed attempt to do this the first time). remember that all cars are different so don't go closing off anything permanently unless you know your car is fine with it. https://www.gassavers.org/showthread.php?t=11764 |
Bookmarked!!! That was excellent, exactly what I was hoping for. And it looks GREAT. Thou dost rawk. :thumbup: |
Thanks for fielding that one BEEF!
Good luck and glad that we could be ome inspiration for your project oneinchsidehop! |
remember that film quality hides a lot of flaws.
I think that you said it best (TomO) "we are our own worst critic" also remember, the more time you spend on it, the better it will turn out. I ended up purchasing a bumper from the local pull-a-part (junk yard) so that I could spend more time on it. |
Wow i like the whole front. Great fab work! Is the only openning there enough to keep your radiator cool, especially during summer. I'm from WI so i though i'd check. I've got a 99 front bumper, so that process could infact help me alot. :thumbup: :thumbup:
I assume you are directing that towards TomO.
I would suggest using plexi-glass or coroplast to cover your grill just to see how much you can get away with before you make it too permanent. I had my grill covered for more than a year before I did mine. as stated above, all cars are different so you have to find out what works for you and also the average temps vary from area to area. in wisconsin you should be able to get away with more than people from other areas (more southern ones) because average temps should be lower. I would say to experiment first and go from there. |
I had mine blocked for nearly two years before actually making that bumper so I knew what size opening I could use. It is big enough to keep the engine within normal operating temps on a 90?F day going 65mph on the highway for 4 hours, even with 45 minutes of stop and go traffic too. |
Thanks BEEF*. Plexiglass? Are there plexiglass that is strong enough, and bendable to be shaped for the openning? Where would be the best place to find something like that? Sorry, 1 more question for you (BEEF*). How do you cut the plexiglass (rotory saw? saw zaw?). Thanks
