Quote:accelerate fairly
Re: Well, this im/tb is for you
It weighs like 10 pounds and
It weighs like 10 pounds and that's mostly the injectors, ;)
Re: On flat roads I go 1st and
damn i forgot your car is lighter than mine by 200 lbs, what's your engine specs? and what kind of wheels do you have put on right now? here are mine: Weights: curb weight (lbs) 2,449 p185/70R14 87S 115 HP SAE @ 6,100 rpm; 110 ft lb , 149 Nm @ 4,500 rpm this is the engine with no vtec. I just did a 3km run and got 55.6 mpg, then I took a 5 min break and did the same run again and achieved 63.5 mpg! for a total of 6 km, which has 2 right turns and three stop signs that i have to turn right on as well. I wonder how many times i can repeat the segment until my mpg maxes out? lol time to find out edit: boo 3rd run resulted in 54mpg but then again I took a 10 minute break for that one and when I got back coolant temperature dropped from 90 C (normal operation) to 70C.... but now at least I know what my car is capable of! |
I have 102 HP, 98 ft lb
I have 102 HP, 98 ft lb torque. No vtec here either. The wheels are 185/65/15 which are way bigger than the stock 175/75/13. That may be costing me a few mpg. Im working on getting smaller tires/wheels.
Quote:I have 102 HP, 98 ft
Re: Quote:I have 102 HP, 98 ft
I'll have to weigh mine, but
I'll have to weigh mine, but also. I could weigh more than you and still have less inertia, especially since the tire weight is mostly at the outside. Think about it...;)
